Rev problem on crx si please help
i just picked up a 89 srx si that has been sitting for a while. we finally get it to run and it wont rev past 3 K. im not sure what the problem is. we thought it was vacume lines, or the intake. we checked all that and that wasnt it. now im thinking its something with the dizzy? let me know what you think. thanks
Damn, you need to give us more information than that.
Are there any codes the ecu is throwing?
If it has anything to do with the distributor, the ecu will go into limp mode and not rev past 3k. I am pretty sure it is the distributor, but you need to tell us what codes it is throwing. You probably have either a code 4,8, or 9.
EDIT: to check for the codes, the ecu is under the passenger floorboard, its under the carpeting under the glove box. (Basically if there was a tall guy in the passenger seat, where his feet would be). Turn the key to the 'on' position. COunt how many times the ecu blinks. You know what? Heres a link that will tell you everything: https://honda-tech.com/zerothread?id=468260
Yeah, rust in the distributor or having it sit for a long time can cause the sensors to go bad. There is probably a check engine light on, so check it out.
civhatch90
27
Nov 29, 2006 09:05 AM
shiithook
13
Apr 30, 2002 06:43 PM
