help with d16y8 swap into a obd1 del sol..ive searched
im swapping in d16y8 into a 94 del sol. now, im using an obd1 dx wire harness (rewired for obd2 injectors and vtec) now i have a few ??
1. for the dizzy, im using my obd2b, ive seen that dizzy rewire pix, but which wire is the the one that doesnt get use again.
2. as far as the bracket on the driver side, i cant use my d16y8 because it only has 2 holes when the del sol uses a 3 hole bracket. my ? is can i use the dx or z6 brackets and would it fir on the y8?
3. also for the rear bracket, can i use the y8 rear bracket?
thnks
thnks
stonet149
Jun 20, 2007 05:55 AM
