Passenger side window repair
Old May 1, 2005 | 12:24 PM
icedlee's Avatar
Default Passenger side window repair
When i bought the car, ididn't knowthe pass side window didnt work.
Today i opned up the door panel and took a look. The washers were ripped in half and the tracks had a lot of dirt in them. The pieces of plastic that are glued onto the window weren't attached.
does anyone know what these are called and where i can get a replacement set?
does anyone know what these are called and where i can get a replacement set? also what type of glue is prefered. Chiltons doesn't have it labelled.
i found this in the door panel, i don't know where it goes, where it came from. does anyone know what this is called?
heres a picture of a the track. would it be better for me to replace the whole set? id rather not.
had a little trouble putting the door panel back on.
any help would be great.
91_CRX_DX
im gettin better at photography
Old May 1, 2005 | 12:34 PM
Cuong-nutz's Avatar
Default Re: Passenger side window repair (icedlee)
It would be a better idea to replace the whole thing unless you have access the needed parts. The black piece you ask look like part of th window track molding. I'm not sure what they're called but you could try looking the parts up on http://www.hondaautomotiveparts.com
Old May 1, 2005 | 01:10 PM
kKdARIAN's Avatar
Vice President/CEO
My window tab broke off right there too.. I called one of those window replacement services and they glued another one on there for $10.
Call around your area'
Your track should be fine, and that black strip should fit into a groove inside the door where your window slides up and down.
92bseries
Apr 8, 2012 08:29 AM
Lightsped
Aug 28, 2008 11:14 AM
taffetawhitegsr
Nov 1, 2004 09:27 PM
EnKidu
Oct 10, 2004 06:43 PM
RATEDR
May 23, 2002 06:39 AM
