does anyone know how to properly disconnect airbags so they dont go off on a ek
Old May 1, 2005 | 11:14 AM
b20turbovtec's Avatar
Default does anyone know how to properly disconnect airbags so they dont go off on a ek
let me know!!! thanks
Old May 1, 2005 | 11:19 AM
turboxsi's Avatar
Default Re: does anyone know how to properly disconnect airbags so they dont go off on a ek (b20turbovtec)
Why would you do this?? Are you autocrossing?? Other than that i don't think you will have much luck passing safety inspection.
Old May 1, 2005 | 11:44 AM
Default Re: does anyone know how to properly disconnect airbags so they dont go off on a ek (turboxsi)
i am putting a sparco wheel on a a screen in the other one....i dont have any safety inspections
Old May 1, 2005 | 11:46 AM
e jay one's Avatar
did you try a search? i know theres a how to on here somewhere.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20turbovtec &raquo;</TD></TR><TR><TD CLASS="quote">i dont have any safety inspections</TD></TR></TABLE>
me either is this only in certain states or something?
Old May 1, 2005 | 12:44 PM
SkRiBLaH's Avatar
Default Re: does anyone know how to properly disconnect airbags so they dont go off on a ek (e jay one)
easy.
remove negitive battery terminal.
wait 10 mins.
unplug and remove airbags.
OR
they will not just fly open. they must get 12v to engauge.
Old May 1, 2005 | 12:48 PM
dc2rboost's Avatar
yeah... they only sucky part is your srs light will be on...
Old May 1, 2005 | 01:23 PM
what if i puncture it will it blow up if the battery is disconnected
Old May 1, 2005 | 01:34 PM
xEnderx's Avatar
The reserve capacitor for the airbags will still be powered up even after you dissconnect the battery. Just to be safe I usually give it 30 minutes to discharge. Make sure you wear some type of gloves when you are removign teh actual airbag module.....static can actually set off the squib. Some latex (fisting) gloves should work just fine. As long as you are careful you shouldn't have any problems.
Old May 1, 2005 | 01:49 PM
but what if it were punctured
Old May 2, 2005 | 10:21 AM
dc2rboost's Avatar
that would be a waste of an airbag... you could sell it and make some bank if someone really needs it...
Old May 2, 2005 | 12:55 PM
turboxsi's Avatar
damn i wish i had no safety inspections. I would disconnect battery and wait like 10-15 minutes. And as far as puncturing it, i would not just because you can resale the air bags for a good price.
Old May 2, 2005 | 12:58 PM
Econo'Box's Avatar
Turn off your car and disconnect bothe battery terminals. Let the car sit for about 5 minutes with the battery disconnected. Then remove the yellow connectors from bothe airbags and replace it withe the red one. Then remove and unhook the LED for the SRS light. If you want you can also go under the dash and reomove the SRS computer as well.
Old May 3, 2005 | 05:22 PM
havin a **** of a time getting the passanger side out i took the 3 bolts off but cant get it to pop up am i missing something
Old May 3, 2005 | 07:20 PM
Econo'Box's Avatar
There should be 4 bolts to the dash and the 4 bolts to the bracket attached to it. They are pretty hard to get at w/o taking the dash out. Ghetto rig some wrenches together and you should be able to get at the last one.
girliehonda
Nov 19, 2007 02:56 PM
Wazup
11
Aug 10, 2006 09:10 AM
tor-scot
Jan 3, 2006 09:31 PM
rex03
May 14, 2003 02:16 AM
