Slide type flange
Old May 1, 2005 | 10:48 AM
RCautoworks's Avatar
Default Slide type flange
Just curious on how many people use this method. Not sure if its called a slide type or slip type. Basically you put a flange onto a pipe and then you expand the one end of the pipe so it basically forms a mouth. I find this way to be very easy an affordable over a collector type flange. Just curious on why I don't see more people using this method.
Old May 2, 2005 | 09:44 AM
Dam anyone ?
Old May 2, 2005 | 05:13 PM
Default Re: Slide type flange (90blackcrx)
How about flared type flange setup ?
Old May 2, 2005 | 06:32 PM
CRXDrew's Avatar
I don't have a flaring tool, but I used a piece like that purchased from Murrays to complete my test pipe.
Old May 2, 2005 | 07:47 PM
Default Re: (CRXDrew)
No ****, Murrys sells them. What sizes ?
Old May 2, 2005 | 08:41 PM
CRXDrew's Avatar
umm 2-3in? I used a 2.5 from there. They have the female cup shape and the male ballish shape.
Murrays kicks ***... haha... only place in town with gallons of paint for under 40 bucks too
Old Jun 27, 2005 | 03:50 PM
This is what I'm talking about, flange goes on the un flared side and slides to the other end.
Old Jun 27, 2005 | 05:49 PM
david@didrace.com's Avatar
Ball-type collector. OEM exhausts have those so there can be some misalignment in an exhaust without any leaks. Not needed if you mock everything up correctly.
Old Jun 27, 2005 | 08:31 PM
Default Re: Slide type flange (backpurge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by backpurge &raquo;</TD></TR><TR><TD CLASS="quote">Ball-type collector. OEM exhausts have those so there can be some misalignment in an exhaust without any leaks. Not needed if you mock everything up correctly.</TD></TR></TABLE>
Even if you line everything up properly I still feel these add a better seal. And there not ball-type collectors but there pretty dam close to it.
Oh and about lining them up, I have installed 4 rs*r catback systems, there top of the line, but they use straight flanges and every single one I put together has leaks. Only thing I could think of, is they warped the flange.
Old Jun 27, 2005 | 09:02 PM
CRXDrew's Avatar
Yep, they carry ends like that @ Murrays. The stock manifold has provisions for a flange like that. (sure you knew that) I'm a big fan of those, allows for shifting w/o worries of bad leaking. Neway... The end of my downpipe had a 2bolt with that type end. Attached to the test pipe with that end and then a stock 3 bolt flange that goes to the exhaust.
Old Jun 27, 2005 | 09:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXDrew &raquo;</TD></TR><TR><TD CLASS="quote">Yep, they carry ends like that @ Murrays. The stock manifold has provisions for a flange like that. (sure you knew that) I'm a big fan of those, allows for shifting w/o worries of bad leaking. Neway... The end of my downpipe had a 2bolt with that type end. Attached to the test pipe with that end and then a stock 3 bolt flange that goes to the exhaust. </TD></TR></TABLE>
You told me before Murrays had them, I looked and saw some garbage looking pieces, I will go back and look some more
Old Jun 28, 2005 | 09:26 PM
blackstar's Avatar
war all of the time......
Default Re: (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">
You told me before Murrays had them, I looked and saw some garbage looking pieces, I will go back and look some more</TD></TR></TABLE>
i've used one before like that, i have one now for sale, its 3inch at the flared end and reduces to a 2.5inch outlet
Old Jun 29, 2005 | 10:43 PM
AspectIndustries's Avatar
Im actually using this method for my 2.5" downpipe and the ends having a 3bolt flange, from there, I run a a 3" exhaust piping all the way back. Seems to work well.
If interested, I can get you some pics. PM me if so.
Old Jul 3, 2005 | 02:51 PM
openloop's Avatar
accually the ball collector is used because as the engine torques the exhaust needs to compensate a rigid joint will soon fail do to stress unless solid mounts are used flowmaster makes great ball joints for exhaust they have a nice transition and dont need a gasket
Old Jul 6, 2005 | 03:30 PM
nuckingfuts's Avatar
Default Re: Slide type flange (openloop)
usually, they leak.
Old Jul 6, 2005 | 06:02 PM
Default Re: Slide type flange (nuckingfuts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nuckingfuts &raquo;</TD></TR><TR><TD CLASS="quote">usually, they leak.</TD></TR></TABLE>
No, usually they don't leak. They seal better then regular flanges.
Old Jul 6, 2005 | 07:03 PM
WOw! My bad, forgot about the pictures.
They do actually seal VERY nicely. I love these. I will try to get some pics tomorrow morning for you 90blackcrx.
Old Jul 7, 2005 | 10:04 AM
Default Re: Slide type flange (synik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by synik &raquo;</TD></TR><TR><TD CLASS="quote">WOw! My bad, forgot about the pictures.
They do actually seal VERY nicely. I love these. I will try to get some pics tomorrow morning for you 90blackcrx. </TD></TR></TABLE>
Thanks, I think I did IM you but I was so busy I forgot to get back to you.
Accurate GS-R
Mar 26, 2005 06:28 AM
CharleyCRX
Nov 19, 2003 03:31 AM
W.Zero
Mar 12, 2003 09:58 PM
Saga
Mar 22, 2002 11:24 AM
