ACT hydro pressure plate on cable tranny
Old May 1, 2005 | 08:29 AM
spidermancivic's Avatar
Default ACT hydro pressure plate on cable tranny
i have a used ACT pressure plate off my 99 civic si (hydro tranny). will it be ok to use that used ACT pressure plate on a b16 cable tranny with a new ACT 6 puck disc?
Also, is it ok to reuse a pressure plate?
Old May 1, 2005 | 07:22 PM
Default Re: ACT hydro pressure plate on cable tranny (spidermancivic)
Old May 1, 2005 | 07:41 PM
DohcVtecCrx's Avatar
well the flywheels fit from 90-99 b series, and the only diffrence in the clutches from 90-93 to 94 and up are the spline count in the disk, so I'd say 85%+ chance that will be the exact same PP as the newer ones.
Old May 1, 2005 | 08:11 PM
Stefndogg's Avatar
yep u can use it....im using a hydro pp...but obviously u need the cable clutch disk
Old May 1, 2005 | 08:19 PM
PURPLETERROR aka BIGMATT's Avatar
Yes it will work fine
Old May 1, 2005 | 08:31 PM
ne3ek's Avatar
Default Re: ACT hydro pressure plate on cable tranny (DohcVtecCrx)
actually 90-91 is diff from 92-up
ne3ek's Avatar
actually 90-91 is diff from 92-up--
as far as clutch discs/spline counts are concerned
-edit didn't mean to double post
MHBb16CRX
Jul 18, 2007 05:14 AM
Beau Gotti
Feb 27, 2006 09:40 PM
SlowSlammedSedan
Dec 2, 2005 02:59 PM
spidermancivic
May 1, 2005 08:25 PM
phrasathane
Feb 10, 2004 05:48 AM
