have an '87 accord pgm - f1 light goes on intermittently
Old Apr 30, 2005 | 10:27 PM
wrxdriver's Avatar
Default have an '87 accord pgm - f1 light goes on intermittently
the car runs fine, has about 140K miles, is manual, but sometimes, for no reason, the "PGM chip F1" red light goes on and seems to stay on until the car is parked.
But the car runs great, the only other problem is sometimes the seat belt buzzer doesn't go off if you don't close the door and get it on within 30 seconds or 1 minute. Any suggestions?? Thanks.
Old Apr 30, 2005 | 11:05 PM
Vanilla Sky's Avatar
pull your code and come back... sounds like EGR, though
Old Apr 30, 2005 | 11:12 PM
wrxdriver's Avatar
Default Re: (Vanilla Sky)
how do you pull the code? What tools are needed?
Old Apr 30, 2005 | 11:43 PM
look under the drivers seat when the car is running and light is on and count the blinks you may have to pop the little tap off the cover to see the window.
copied from a post by robt5580 on 3geez
Old May 1, 2005 | 12:10 AM
wrxdriver's Avatar
Thanks, I will check this out.
Old May 2, 2005 | 12:56 PM
wrxdriver's Avatar
Default Re: (wrxdriver) -- 12 red blinks
OK, when the PGM-F1 red light goes on at random, and stays on until the car is shut down ('87 5 spd, Coupe Accord), the red light under the seat blinks 12 times. Does that correlate to anything? Thanks!
Old May 2, 2005 | 02:59 PM
deserthonda's Avatar
i believe code 12 is for the egr system..,,,
Old May 2, 2005 | 06:00 PM
Chiovnidca's Avatar
Default Re: (wrxdriver) -- 12 red blinks (wrxdriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrxdriver &raquo;</TD></TR><TR><TD CLASS="quote"> ('87 5 spd, Coupe Accord), the red light under the seat blinks 12 times. Does that correlate to anything? Thanks!</TD></TR></TABLE>
The first thing I check on those is to see if the vacuum chamber in the control box is clogged.
Chiovnidca's Avatar
Default Re: (deserthonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">i believe code 12 is for the egr system..,,,</TD></TR></TABLE>
I beleive you are correct.
Old May 2, 2005 | 06:41 PM
wrxdriver's Avatar
Default Re: (Chiovnidca)
Thanks all,
Is the fact that it is intermittent, and comes on randomly, but never shuts off until the engine is turned off consistent with the EGR diagnosis?
Old May 2, 2005 | 06:48 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrxdriver &raquo;</TD></TR><TR><TD CLASS="quote">Thanks all,
Is the fact that it is intermittent, and comes on randomly, but never shuts off until the engine is turned off consistent with the EGR diagnosis? </TD></TR></TABLE>
That's pretty much normal for that code.
Old May 3, 2005 | 09:30 AM
wrxdriver's Avatar
&gt; The first thing I check on those is to see if the vacuum chamber in the control box is clogged.
OK, I'm a newbie, how do I check this? Where is the vacuum chamber in the control box, is that under the seat in the black plastic enclosure?
Old May 3, 2005 | 02:26 PM
Chiovnidca's Avatar
OK, I'm a newbie, how do I check this? </TD></TR></TABLE>
A helms manual for your model will give a good step by step procedure to diagnose the EGR system.
Old May 4, 2005 | 03:43 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrxdriver &raquo;</TD></TR><TR><TD CLASS="quote">... the red light under the seat blinks 12 times...</TD></TR></TABLE>Just a silly question about the older ECUs... Don't they use the long/short flashes like newer ones? Code 12 on a newer car would be 1 long & 2 short.
Old May 4, 2005 | 06:46 AM
yup, that's the EGR code...
and these cars only have like 14 codes...
Old May 4, 2005 | 01:41 PM
Chiovnidca's Avatar
Default Re: (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Just a silly question about the older ECUs... Don't they use the long/short flashes like newer ones? </TD></TR></TABLE>
Nope there wasn't any need to, there weren't very many codes like Vanilla Sky said.
Argenis 2524
Feb 5, 2016 11:48 PM
Lou_EM1
Feb 26, 2015 06:45 PM
03EXL
13
Feb 21, 2014 09:10 PM
Cpt Marvel
14
Dec 18, 2012 12:59 PM
vectorvtec73
Dec 29, 2010 08:00 AM
