ls/vtec turbo set up, need help
Old Apr 30, 2005 | 10:06 PM
DFW's Avatar
DFW
Default ls/vtec turbo set up, need help
I'm thinking about doing a ls/vtec turbo set up soon and was just wondering if there's anything I need to look out for or if there are any good parts to make it more reliable. Here's what I'm thinking so far...
-B18B Block
-B16a2 head
-GSR cams
-Arp Head studs
-GSR tranny
-p72 or p28 ecu
-Stock sleeves
-Stock head?
-Stock pistons/rods
-Tial 38mm Wastegate
-Tial BOV
-Full-Race/Neukin mani
-3" Downpipe
-Precision 680cc injectors
-Precision "middle size" fmic
-Not sure on what turbo
-Walbro 255 LPH Fuel Pump
-Neptune
I think that's it... Wanting to get around 350whp.
Old Apr 30, 2005 | 10:28 PM
mtber's Avatar
Default Re: ls/vtec turbo set up, need help (DFW)
I run a simular setup & make 280 on 9lbs using a 57 trim 63ar turbo.
Check the link in my sig for my f/s car for specs/dyno etc.
Old Apr 30, 2005 | 10:31 PM
DFW's Avatar
DFW
Default Re: ls/vtec turbo set up, need help (mtber)
Are diff valves & springs necessary?
Old Apr 30, 2005 | 10:39 PM
mtber's Avatar
Unless you plan on revving past 8k, no.
Old Apr 30, 2005 | 10:42 PM
mrDFWmechanic's Avatar
i went ahead and upgraded the valvetrain just so i dont have to worry about them later. 475 for valves, springs and retainers from stan at fast-turbo.
why are you gonna spend 1200 on a fullrace mani spend half that on a inlinefour mainfold, put the left over money on other stuff
Old Apr 30, 2005 | 10:45 PM
DFW's Avatar
DFW
Default Re: (iROCKtheSOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iROCKtheSOHC &raquo;</TD></TR><TR><TD CLASS="quote">i went ahead and upgraded the valvetrain just so i dont have to worry about them later. 475 for valves, springs and retainers from stan at fast-turbo.
why are you gonna spend 1200 on a fullrace mani spend half that on a inlinefour mainfold, put the left over money on other stuff </TD></TR></TABLE>
That's why I put Neukin in there too, just a rough idea on what I want..
Old Apr 30, 2005 | 11:27 PM
mtber's Avatar
Default Re: (DFW)
Honestly, if you want to make 350 daily.
I would recommend some cp pistons & eagle rods :-)
Old May 1, 2005 | 04:56 AM
Rod.'s Avatar
Default Re: (mtber)
i just did supertech springs and retainers to my ls/vtec just in case
the most part we have similar setup
Old May 1, 2005 | 11:32 AM
DFW's Avatar
DFW
Default Re: (redturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">i just did supertech springs and retainers to my ls/vtec just in case
the most part we have similar setup</TD></TR></TABLE>
What are you reving to? And anyone have any good suggestions for a good turbo for this setup?
Old May 1, 2005 | 01:24 PM
DFW's Avatar
DFW
Default Re: (DFW)
Also to add to the list Golden Eagle ls/vtec kit.
Old May 1, 2005 | 01:53 PM
i'd throw in some pistons and rods just to strengthen the bottom end. at least get the arp rod bolts if your gonna use stock pistons and rods
Old May 1, 2005 | 01:56 PM
joepiscapo_83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">Unless you plan on revving past 8k, no.
i used to rev to 8700 on stock b16a valvetain. pretty badass man...good luck with the build!
go with an sc61....nice for ls/vtec and will support good #'s when and if you want to build your ebgine more.
Old May 1, 2005 | 02:01 PM
DFW's Avatar
DFW
Default Re: ls/vtec turbo set up, need help (v8killr83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iROCKtheSOHC &raquo;</TD></TR><TR><TD CLASS="quote">i'd throw in some pistons and rods just to strengthen the bottom end. at least get the arp rod bolts if your gonna use stock pistons and rods</TD></TR></TABLE>
anyone else with stock bottom end using stock rod bolts or diff ones?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v8killr83 &raquo;</TD></TR><TR><TD CLASS="quote">
i used to rev to 8700 on stock b16a valvetain. pretty badass man...good luck with the build! </TD></TR></TABLE>
used to? were you makeing power all the way up there?
Old May 1, 2005 | 02:25 PM
the rod bolts are the weakest point in the bottom end and its always good to spend the 100 bucks and upgrade them. shoot i have the arp headstuds, rod bolts and main studs. just because i dont want something to break on me and ruin my sleeved block
its just extra insurance and worth it
Old May 1, 2005 | 02:28 PM
DFW's Avatar
DFW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iROCKtheSOHC &raquo;</TD></TR><TR><TD CLASS="quote">the rod bolts are the weakest point in the bottom end and its always good to spend the 100 bucks and upgrade them. shoot i have the arp headstuds, rod bolts and main studs. just because i dont want something to break on me and ruin my sleeved block
its just extra insurance and worth it </TD></TR></TABLE>
Thanks
Old May 1, 2005 | 05:05 PM
DFW's Avatar
DFW
Default Re: (DFW)
anyone else?
Old May 1, 2005 | 05:12 PM
what else do you wanna know. you have any idea on what turbo your gonna be using. it might also be a good idea to look into micropolish and balancing the bottom end. do you plan on boring your block over any ? maybe to 81.5mm.
Old May 1, 2005 | 06:46 PM
DFW's Avatar
DFW
The idea of building the bottem is still in mind...but if I dont, boring it to 81.5mm is good for stock block but if I end up building the bottom end I'll probably bore it to 84 or 84.5. As for a turbo, not sure yet.
Old May 1, 2005 | 08:03 PM
Rod.'s Avatar
Default Re: (DFW)
rev to 8500
Old May 1, 2005 | 08:15 PM
DFW's Avatar
DFW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">rev to 8500</TD></TR></TABLE>
What's done to your block?
Old May 1, 2005 | 08:40 PM
Rod.'s Avatar
Default Re: (DFW)
sleeved, cp pistons and rods
Old May 1, 2005 | 08:48 PM
DFW's Avatar
DFW
damn, im really leaning towards building the bottom end
Old May 1, 2005 | 09:16 PM
Dunc's Avatar
BCICAN
Default Re: (DFW)
You should definitely build the block! I am now regretting the decision to sleeve at a later date when I put the pistons/rods in. Boost is addicting, and you will want more and more power. Sleeve now, be happy sooner!
Old May 1, 2005 | 09:18 PM
DFW's Avatar
DFW
Default Re: (Dunc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc &raquo;</TD></TR><TR><TD CLASS="quote">You should definitely build the block! I am now regretting the decision to sleeve at a later date when I put the pistons/rods in. Boost is addicting, and you will want more and more power. Sleeve now, be happy sooner!</TD></TR></TABLE>
Yeah, I've was thinking about for couple days now. Mines as well do it the first time...
Spoolinls
Jul 1, 2011 10:31 AM
ppiart
May 26, 2011 09:09 AM
jdmb16turbo
May 13, 2009 07:00 PM
lilbluehatch1
May 2, 2005 08:39 PM
romeirome1
Jan 13, 2004 07:30 PM
