Need an opinion on motor choice for turbo application
My plans are to have a mild build d-series block that will be turbo'd around 15psi. I was wondering what motor choice would yield more HP in the end. Whichever motor choice I go with will be converted to OBD1 tuned on Uberdata.
D16a6 block // D16z6 head (aka mini me)
-or-
Complete D16z6 block and head
-or-
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk.Werkz »</TD></TR><TR><TD CLASS="quote">
-or-
Complete D16z6 block and head</TD></TR></TABLE>
Out of those 2 you have here, I would take the complete Z6 block and head because it will yield a lower compression which can take more boost because you can tune it easier. The ideal setup for d-series turbos is the no-tec setup. You take a vtec block and put a non-vtec head on it. (no-tec) Which comes to not having vtec and a compression ratio or 8.x. With no vtec to tune and a low compression ratio, you can crank up the boost.
-or-
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 »</TD></TR><TR><TD CLASS="quote">Out of those 2 you have here, I would take the complete Z6 block and head because it will yield a lower compression which can take more boost because you can tune it easier. The ideal setup for d-series turbos is the no-tec setup. You take a vtec block and put a non-vtec head on it. (no-tec) Which comes to not having vtec and a compression ratio or 8.x. With no vtec to tune and a low compression ratio, you can crank up the boost.
So what would you suggest? z6 block with a6 head?
</TD></TR></TABLE>So what would you suggest? z6 block with a6 head?
good luck finding any info about "no-tec" im gonna try it tonight ill let you know how it works. the z6 boots pretty good it can handle about 13lbs all day with a zdyne and 450cc injectors but the head doesn't flow all that great
harvey121
16
Aug 9, 2021 05:38 PM
Terrabomb
Oct 29, 2004 02:53 AM
HONDA92HATCH
Aug 30, 2004 02:44 PM
