Dynoed a 196,500 mile GS-R today !!! results inside..........
Old Apr 30, 2005 | 08:37 PM
MikeTV
Guest
Posts: n/a
Default Dynoed a 196,500 mile GS-R today !!! results inside..........
So I bought my 196,500 mile gs-r to the dyno today and these were the results......
testing was done on a dynojet dyno. Both pulls were 3rd gear pulls.
Intake air temp: 60.9 degrees
Vapor pressure: .4 in.Hg
Barometric pressure: 29.80 in.Hg
First pull was 153.1 whp (156 SAE corrected) and 114.5 ft lbs of torque (116 SAE corrected).
Mods: bone stock motor
thermal exhaust
skunk2 chipped ecu
aerospeed grounding wires
power steering removed with padawans kit ( finally proof that this makes a big difference !)
THATS IT ! Intake was stock, header and cat were also stock.
For the second pull, all we did was bolt in my buddy's custom header.
160 whp (163 SAE corrected) amd 122 ft lbs of torque (124 ft lbs SAE corrected)
What do you guys think ? I think that pretty damn good for a 196,000 mile motor !
From what i understand, stock gs-rs put down around 150ish, if they are in perfect running condition, so I think the fact that I was able to hit 163 with so many miles on just a bolt on exhaust and header, with a skunk2 chip and grounding kit kicks ***.....
I have a jpeg of the dyno graph , but we-todd-did-racing is flaking out for somer eason. If someone could temporarily host the dyno chart, I would appreciate it; thanks for looking guys !
Modified by TheSaint at 5:14 AM 5/3/2005
Old Apr 30, 2005 | 08:41 PM
Liquidgsr's Avatar
Default Re: Dynoed a 196,500 mile GS-R today !!! results inside.......... (TheSaint)
damn...thats fauking good. I wonder what id run having 140k on my gsr. Seriously doubt having anywhere close to that.
Old Apr 30, 2005 | 09:35 PM
ribbie03's Avatar
Thats crazy!
Old Apr 30, 2005 | 10:05 PM
EnjoyTheRideDC2's Avatar
Default Re: Dynoed a 196,500 mile GS-R today !!! results inside.......... (ribbie03)
Good running motor....
...Now maybe I should take a run on the dyno. Anyone know of one in the so cal area where I wont get laughed at??? hehe.
Old May 1, 2005 | 12:06 AM
Spec R's Avatar
Default Re: Dynoed a 196,500 mile GS-R today !!! results inside.......... (EnjoyTheRideDC2)
Boy....you guys will applaud when you see my dyno graphs....i'll post when i get home.
Old May 1, 2005 | 12:10 AM
Integ-boy's Avatar
that is a good run, but is that 196,500 miles on the same engine or was there a swap?
Old May 1, 2005 | 05:59 AM
MikeTV
Guest
Posts: n/a
Default Re: (Integ-boy)
196,500 miles all original parts on the engine. Nothing has been changed at all. The only thing changed recently was the timing belt ! How about those Hondas !
Old May 1, 2005 | 07:52 AM
Default Re: (TheSaint)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheSaint &raquo;</TD></TR><TR><TD CLASS="quote">196,500 miles all original parts on the engine. Nothing has been changed at all. The only thing changed recently was the timing belt ! How about those Hondas ! </TD></TR></TABLE> even at 292,000
Old May 1, 2005 | 08:45 AM
s2kkid's Avatar
Default Re: (EnjoyTheRideDC2)
197,500 + GSR.
Sounds good.
I just rebuilt at 197,400 due to the turbo setup im heading for...
Still was running decent when pulled.
Old May 1, 2005 | 09:26 AM
riceball777's Avatar
great numbers
but i think your supose to dyno on 4th gear not 3rd
ever tuner that i seen always does 4th gear pulls
Old May 1, 2005 | 04:28 PM
MikeTV
Guest
Posts: n/a
Default Re: Dynoed a 196,500 mile GS-R today !!! results inside.......... (riceball777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">great numbers
ever tuner that i seen always does 4th gear pulls </TD></TR></TABLE>
really ? The dyno emperor told me that hondas should always be dynoed in 3rd...
Old May 1, 2005 | 06:33 PM
Integ-boy's Avatar
really ? The dyno emperor told me that hondas should always be dynoed in 3rd...</TD></TR></TABLE>
yeah from what i have heard, 3rd gear is the right gear also
Old May 1, 2005 | 07:41 PM
danteisme's Avatar
Loved
Community Favorite
Default Re: Dynoed a 196,500 mile GS-R today !!! results inside.......... (Integ-boy)
arent you supposed to dyno the car when the speedo and rpms are increasing almost in sync? which would be fourth i believe?
Old May 1, 2005 | 08:11 PM
Default Re: Dynoed a 196,500 mile GS-R today !!! results inside.......... (danteisme)
3rd gear pulls usually show the best presentable power ratings....
4th gear pulls show the best true representation of your engine's power.
This is all my assumption based on comparing my last 2 dyno sheets
Old May 2, 2005 | 06:09 AM
MikeTV
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnjoyTheRideDC2 &raquo;</TD></TR><TR><TD CLASS="quote">3rd gear pulls usually show the best presentable power ratings....
This is all my assumption based on comparing my last 2 dyno sheets</TD></TR></TABLE>
haha well 3rd or 4rth gear, 196,000 miles is 196,000 miles ! I see alot of threads where people are asking whether they shoudl get a high mileage gs-r....heres the answer lol
Old May 2, 2005 | 09:34 AM
MikeTV
Guest
Posts: n/a
bump for anyone that can host my dyno sheet
Old May 2, 2005 | 09:59 AM
nc_mx_kid's Avatar
Nice
Old May 2, 2005 | 10:19 AM
RuskeR's Avatar
sounds like a good motor.
Old May 2, 2005 | 06:28 PM
MikeTV
Guest
Posts: n/a
Default Re: (RuskeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RuskeR &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a good motor. </TD></TR></TABLE>
thank you
Old May 2, 2005 | 07:20 PM
Ohhenrygsr's Avatar
i'll host it send it over
henny26@rogers.com
Old May 2, 2005 | 07:33 PM
iH8RICERZ's Avatar
Default Re: Dynoed a 196,500 mile GS-R today !!! results inside.......... (Ohhenrygsr)
AWESOME! I hope my high mileage gsr can still pull good numbers by the time I dyno again
Old May 2, 2005 | 07:43 PM
Evanmb44's Avatar
3rd and 4th gear make the same amount of power
Old May 2, 2005 | 10:18 PM
mugenracer's Avatar
Your supposed to dyno in the gear with the nearest ratio to 1....3rd gear in a GSR is 1.36 and 4th gear is 1.034...so 4th gear is the correct gear.
Old May 3, 2005 | 07:18 AM
l4zo's Avatar
lol damm goo gsr ! that still running good
Old May 3, 2005 | 10:19 AM
MikeTV
Guest
Posts: n/a
Default Re: (mugenracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenracer &raquo;</TD></TR><TR><TD CLASS="quote">Your supposed to dyno in the gear with the nearest ratio to 1....3rd gear in a GSR is 1.36 and 4th gear is 1.034...so 4th gear is the correct gear.</TD></TR></TABLE>
gotcha
artin01
Apr 27, 2010 09:48 PM
Slow_import
Jul 26, 2009 06:14 PM
jdmintegraxsi
44
Jul 11, 2006 03:36 PM
MiKeAhOwSkI
28
May 1, 2005 11:34 PM
coyotes fan
Apr 12, 2003 09:00 AM
