Will S2000 seats fit in the 94+?
Old Apr 30, 2005 | 07:43 PM
Aracheon's Avatar
Default Will S2000 seats fit in the 94+?
Like the title says, will S2K seats fit into the Gen3 Integra? 2-door, if that makes a difference.
Has anyone done this before?
Old Apr 30, 2005 | 07:46 PM
Kendall's Avatar
The front bolts go in fine, but the rears don't line up at all.
Old Apr 30, 2005 | 07:55 PM
Aracheon's Avatar
Is it possible to swap the seat rails?
Old Apr 30, 2005 | 07:56 PM
Racermech's Avatar
Default Re: (Kendall)
Kendall, Have you actually seen S2K seats in a teg??
Reason i ask is i wonder if you could cut/bend the rear tabs, belt a little plate with a new hole and bolt them down that way. Or are they too wide? too narrow? short?long?....etc
Old Apr 30, 2005 | 08:05 PM
Kendall's Avatar
Default Re: (Racermech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racermech &raquo;</TD></TR><TR><TD CLASS="quote">Kendall, Have you actually seen S2K seats in a teg?</TD></TR></TABLE>
Many, many times.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racermech &raquo;</TD></TR><TR><TD CLASS="quote">Reason i ask is i wonder if you could cut/bend the rear tabs, belt a little plate with a new hole and bolt them down that way. Or are they too wide? too narrow? short?long?....etc</TD></TR></TABLE>
You can easily get away with some cutting, bending, and bolting.
Old Apr 30, 2005 | 08:24 PM
uzabatty's Avatar
Default Re: Will S2000 seats fit in the 94+? (Aracheon)
yeah, it's been done...
not sure if I've seen it here or on T-I though
Old Apr 30, 2005 | 08:28 PM
Racermech's Avatar
Default Re: Will S2000 seats fit in the 94+? (uzabatty)
Interesting. Yet another option for seats.
Old Apr 30, 2005 | 09:13 PM
Aracheon's Avatar
The option's been presented, but I'm just curious as to how much work I'm going to have to put into making them fit. If it's just a matter of cutting the rear tabs and re-welding them in a different spot...
I'd be interested to know if anyone's got pictures of how they made it work.
Old Apr 30, 2005 | 09:18 PM
Aracheon's Avatar
Here's something I found from T-I
http://www.team-integra.net/fo...earch
Old Apr 30, 2005 | 09:32 PM
THALADOR's Avatar
Default Re: (Aracheon)
its been done before, you have to replace the seat pans from a teg on the s2000 seats, and you will have a flawless fit.
https://honda-tech.com/zerothread?id=347548
Old Apr 30, 2005 | 11:03 PM
Cliffjumper2's Avatar
Default Re: (THALADOR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THALADOR &raquo;</TD></TR><TR><TD CLASS="quote">its been done before, you have to replace the seat pans from a teg on the s2000 seats, and you will have a flawless fit.
https://honda-tech.com/zerothread?id=347548</TD></TR></TABLE>
good link
Old May 1, 2005 | 07:29 AM
Aracheon's Avatar
EXCELLENT link... I did a search and that didn't even come up...!
Thanks, man.
Old May 2, 2005 | 08:27 AM
Aracheon's Avatar
Well, I got the seats, swapped over the pans and rails from an EG Civic, and they fit just fine! They sit about 2" lower in the *** of the seat, and the front part of the cushion sits about 2" higher... so you're kinda leaning back when you drive. I can't really rest my hand on top of the steering wheel when I drive anymore. Other than that, they sit extremely comfortable, and I've noticed that I shift differently too.
Pictures to come once I get a camera.
Old May 2, 2005 | 09:44 AM
95lstegman's Avatar
i missed the point . . . why do you want S2K seats? they cost a hell of a lot. for that price you could be enjoying 12lb Fiberglass seats that are equally as comfortable and have sliding rails to go along with them. plus, you would have dropped about 60lbs, and you'd have cloth to hold you in (leather doesn't do as well). either these seats are cheaper than i think or somebody likes to do things that don't make sense.
Old May 2, 2005 | 11:49 AM
Aracheon's Avatar
The seats cost me nothing. I traded them for a digital camera that I was selling.
Now, if you can point me in the direction of a set of Corbeau Targa TRSs with Integra rails for under $550, please, by all means. I've never found a set of fiberglass racinig seats that were comfortable enough to me for daily driving, which is what my DC is currently being used for.
I DO agree with you on the cloth vs. leather bit, though. I'd much rather have a seat covered with the cloth that the ITR seats have rather than cowskin.
Old May 2, 2005 | 11:51 AM
be.twenty's Avatar
how is it when doing a saftey? ...will it pass?
Old May 2, 2005 | 12:00 PM
THALADOR's Avatar
Default Re: (shogun-dc2)
it should pass, it fits like oem, and you supposedly sit only an inch lower than the stock height....
Old May 2, 2005 | 06:56 PM
JDX's Avatar
JDX
Aracheon: Safety inspections are not required where I live, nor are emissions in my county. The seats feel like they sit closer to about 2" lower on the back of the seat cushion, but about 2" higher in the front where your knees go.
Old May 2, 2005 | 07:03 PM
SdGSR01's Avatar
Default Re: (JDX)
I have some in my teg, mines came with the rails though
SdGSR01's Avatar
Default Re: (JDX)
Old May 2, 2005 | 08:54 PM
JDX's Avatar
JDX
Came with EG rails, you mean?
The S2K rails WILL NOT bolt into a 3rd gen Teg as they are...
c-rex23
Honda S2000
12
Oct 13, 2009 03:29 PM
vietdragontekx
Honda S2000
Apr 2, 2008 07:34 PM
631 Teggy
Honda S2000
11
Jan 10, 2008 01:37 PM
05RSX
Honda S2000
Aug 8, 2006 09:08 PM
sportyolds
May 18, 2004 07:25 PM
