might be getting another G2, engine internal parts question (B17)
Old Apr 30, 2005 | 07:14 PM
JustinG60's Avatar
Default might be getting another G2, engine internal parts question (B17)
are there any connecting rods that will work from another B series on the B17? if i recall B16 rods will work, i just need to make sure i have a B17 crank right?
Old Apr 30, 2005 | 07:26 PM
Kendall's Avatar
The B16A and the B17A1 both use PR3 blocks. The only displacement difference is in the stroke. No other B series rods are the same length as the B17 rods due to this stroke difference. If you use B16 rods, make sure to have a B16 crank, likewise if you use B17 rods, make sure to have a B17 crank.
Old May 1, 2005 | 07:29 AM
JustinG60's Avatar
Default Re: (Kendall)
anyone else want to confrim that cause i've heard other wise on here...
Old May 8, 2005 | 11:56 AM
FIGARILA's Avatar
Default Re: might be getting another G2, engine internal parts question (JustinG60)
he's right... the p61 rods are different then other rods. you can use b16 rods but i belive b17 rods are shorter than b16 rods.
Old May 8, 2005 | 05:54 PM
JustinG60's Avatar
Default Re: might be getting another G2, engine internal parts question (FIGARILA)
thanks for jumpin in i appreciate it, but i did find all the rod lengths for all the B series engines... took a me a while but i came up with em
sxysweed
May 29, 2012 06:43 PM
1point7T
Mar 30, 2004 06:56 AM
mr. wu
Oct 7, 2003 10:00 AM
mr. wu
Oct 5, 2003 11:16 PM
delslow94
Feb 18, 2003 05:32 PM
