How to measure ring gap with domed pistons????
Im trying to measure ring gap and my P73 pistons dont make the ring seat true on the bore when pushing it down giving a false reading on ring end gap.
How do you go around to do this??
TIA
TIA
the dome is not that big..you should be fine when stuffing it in the cylinder to square up the ring for measurment...if its alittle off after you pull out the piston align the ends carefully together by hand..this is what i do and works perfect..everyone has their own way though...
All dome pistons I have seen will have a flat ridge on the top of the dome. IT is not like the dome is an actual tent where two slopes meet at one point. It is more like two slopes meet with a small gap between that is connected. Like this
(Shameless plug for my 7.7CC 86mm CP's!) To much bling for me. Not used to it. lol
push the ring down about an inch into the cylinder. I think this should be sufficient for most pistons.
once its "squared" in the bore, use your feeler guage to check the gap.
I just use a carpenters square.Set it at one inch.Put the ring in the bore,and work the square around the bore while bringing the ring up against it. http://www.sears.com/sr/javasr...uares
Glenn
Glenn
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF »</TD></TR><TR><TD CLASS="quote">.014-.016 is OK I like them alittle tighter with a 600 finish for NA. Now I have to try Heinekins.</TD></TR></TABLE>
As if either of us needed another excuse for Heineken right. :-)
civic-steve-94
Engine Machining & Assembly
Sep 16, 2016 04:20 PM
Suck my DX
27
Apr 9, 2007 12:43 PM
