header install now theres a rattle
Old Apr 30, 2005 | 01:17 PM
chinaski's Avatar
Default header install now theres a rattle
i just installed a set of Dc 4-2-1 headers in my 96 GSR and now i have a rattling noise that seems to be coming from around the catalytic converter. i checked everything, nothing is loose and the header is not vibrating on the engine block. anyone have a solution or have had this problem? it sometimes has a rattling noise when im driving and when my car is idling around 500rpms
Old Apr 30, 2005 | 01:19 PM
apok's Avatar
Default Re: header install now theres a rattle (GeeSeR96)
You should raise your idle. Stock idle is 750 +-50.
swanny's Avatar
Heat shield on cat? do a search i think there is a big thread on the misc. teg noises and solutions.
Old Apr 30, 2005 | 03:38 PM
H.crx-si
Guest
Posts: n/a
It could be your heat shield as he said. Rip it off and if you still get a rattle it's very possible that it could be rattling against the heatshield thats right above the cat against the body itself.
Old Apr 30, 2005 | 03:59 PM
Rpizzle's Avatar
yeah heat shield, take that off and fab a new one
Old May 3, 2005 | 06:53 AM
chinaski's Avatar
Default Re: (H.crx-si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rpizzle &raquo;</TD></TR><TR><TD CLASS="quote">yeah heat shield, take that off and fab a new one</TD></TR></TABLE>
yeah its definately the heat shield after the cat because i noticed some scratches from it on the exhaust piping. would there be any problems if i just took the heat shield off and didnt fab a new one?
Old May 3, 2005 | 07:03 AM
simon98h22's Avatar
Default Re: (GeeSeR96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GeeSeR96 &raquo;</TD></TR><TR><TD CLASS="quote">
yeah its definately the heat shield after the cat because i noticed some scratches from it on the exhaust piping. would there be any problems if i just took the heat shield off and didnt fab a new one?</TD></TR></TABLE>
No, your cabin might heat up a bit more but it'll be fine.
BTW, it's header not headers
Old May 3, 2005 | 07:04 AM
Thrasher's Avatar
No, no problems without a heatshield I don't think, but thats probably not what it is. Unless its just a coincidence that it happened when you installed the header, I would say that the mounting bracket is loose. When I put a header on my friend's LS, the 2 bolts on the bracket didn't line up right and it rattled.
Old May 3, 2005 | 07:08 AM
be.twenty's Avatar
Default Re: (simon98h22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simon98h22 &raquo;</TD></TR><TR><TD CLASS="quote">No, your cabin might heat up a bit more but it'll be fine.
BTW, it's header not headers </TD></TR></TABLE>
well there's the problem.... he installed TWO manifolds!!!
Old May 4, 2005 | 10:01 AM
chinaski's Avatar
Default Re: (Thrasher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thrasher &raquo;</TD></TR><TR><TD CLASS="quote"> I would say that the mounting bracket is loose. When I put a header on my friend's LS, the 2 bolts on the bracket didn't line up right and it rattled.</TD></TR></TABLE>
yeah thats whats the problem with my header. the two screws that connect the cat to the header dont line up too well and the cat is at a bit of an upward angle. im guessing now that the header i bought got bent when it was scraped. when i got the header, the previous owner had dented them.
96GeeSR
Feb 28, 2009 12:55 PM
NinjaTech
Mar 9, 2005 05:14 PM
es_squared
Sep 3, 2004 10:48 AM
oryanh
Aug 30, 2002 01:15 PM
Keane Rated R
Sep 25, 2001 12:54 AM
