A total noob question.....about timing
Old Apr 30, 2005 | 08:54 AM
ApolloSpeed's Avatar
Default A total noob question.....about timing
After My b16 starting bogging and running bad..... and black stuff running out the pipes.
I wanna check my timing,
So.
The #1 plug wire is the bottom left (looking at the dizzy)
then I start the motor, and point the light where ? The crank pulley ?
Old Apr 30, 2005 | 09:04 AM
SwapShopR's Avatar
No Sales Forums
Default Re: A total noob question.....about timing (ApolloSpeed)
Yes the timing marks are on the crank pulley, there is also another (pointer) on the plastic timing belt cover (you will need). Those motors generaly run well at 17 degrees advance. I would set it there.
Old Apr 30, 2005 | 09:09 AM
Default Re: A total noob question.....about timing (SwapShopR)
I dont see any timing marks.......do I need to take anything off the motor to see the marks ?
Old Apr 30, 2005 | 09:14 AM
Kamin's Avatar
no, you just need to know what you are looking for. there are marks on the pulley (one is pink if i remember right) and there is a solid line that is raised on the timing belt cover. point from the back of the car down at the pulley
Old May 1, 2005 | 08:31 AM
Default Re: A total noob question.....about timing (Kamin)
ok....I see.....so at idle it should be right on the marks...right ?
NSfit
Nov 26, 2006 07:34 PM
redcrx1
Nov 29, 2003 06:40 AM
wantmorepower
Apr 15, 2003 08:07 PM
OBD-One-Kanobe
Nov 1, 2002 09:21 AM
