Anyone bypass the IACV when installing Hondata intake gasket?
Old Apr 30, 2005 | 08:06 AM
hughesl's Avatar
Default Anyone bypass the IACV when installing Hondata intake gasket?
I already plugged the cold idle valve, but I was wondering if anyone left the IACV hooked up the electrical connection, but disconnected the coolant lines from it?
If you did what was the consiquence of disconnecting the coolant?
Thanks for the help.
Old Apr 30, 2005 | 08:17 AM
dr_latino999's Avatar
Default Re: Anyone bypass the IACV when installing Hondata intake gasket? (hughesl)
Doesn't seme to be any problem disconnecting the coolant if you live in the warm climate - https://honda-tech.com/zerothread?id=596485
Old Apr 30, 2005 | 11:59 AM
bagpipe goatee's Avatar
mine was messed up, and when i switched over last week i was lazy and didn't mess with the coolant lines, so it works fine. however, i'll probalby have to connect them before winter, assuming i still have this dying motor.
Old Apr 30, 2005 | 01:51 PM
hughesl's Avatar
Default Re: Anyone bypass the IACV when installing Hondata intake gasket? (dr_latino999)
Thanks for the link.
That exactly what I needed.
Dan GSR
Jul 24, 2003 08:51 AM
Sinner
May 29, 2003 10:41 AM
Doctor CorteZ
Feb 13, 2002 01:53 AM
