Radiator fan inoperative
Old Apr 30, 2005 | 06:41 AM
Dual_Phart_cans's Avatar
Default Radiator fan inoperative
Ive changed every sensor that has to do with my coolant system, yet my fan still fails to turn on . . .is there any possible way the thermostat could be causing this? anything else i should try?
Old Apr 30, 2005 | 07:42 AM
THugluv423's Avatar
Default Re: Radiator fan inoperative (Dual_Phart_cans)
check relay. Put a jumper in between the plugs for the relay in the fuse box. There should be four diferent ones. Put the jumper in parallel pairs with two then try the other two. If the fan comes on It could be your relay.
Old Apr 30, 2005 | 11:20 AM
alright, thanks man =]
Old May 1, 2005 | 12:50 AM
Yoshiod9's Avatar
From: vacaville for holiday, sacto for school, ca, united states
thugluv- i'm not sure about what you mean by parallel pairs...i'm having the same problem with my rad. fan. it's not the motor and i'm thinking it might be the relay. lmk what you mean. thanks in advance.
Old May 1, 2005 | 11:12 AM
Yoshiod9's Avatar
anyone??
Old May 2, 2005 | 08:41 AM
i dunno man, but make sure you have enouph coolant, thats what was ******* me over, take ur cap off and start the car and keep fillnig ur radiator untill it stopos going down, it was causing my heat not to work, my thermostat not to open, and my fan not to turn on.
Old May 2, 2005 | 10:22 AM
Yoshiod9's Avatar
i've definetly got enough coolant...cuz the thermostat opens and i can feel the upper hose get hot from the coolant flowing through it. it's just the fan isn't turning on.
Old May 2, 2005 | 01:47 PM
check ur connections and then pull the plug out of the top of you radiatro fan and run to wire streight to the battery . .. if it dosent tur on replace your fan motor, then if that dosent work try replacing the fan switch . . . . its on the thermostat housing
Old May 2, 2005 | 02:04 PM
Yoshiod9's Avatar
well i know it's not the fan motor...i'm not sure how to check the relays though. i'd rather check them to make sure they function before i go and buy a new engine coolant temperature switch and not have that solve the problem. also, is the fan switch you're talking about the same as the engine coolant temperature(ect) switch? thanks.
Old May 2, 2005 | 03:15 PM
eg6roll's Avatar
A quick fix is to hot wire the guy to a toggle swith in the car. Just flip it when you get to driving it. Turn off when your done. That's what I did for a week, till I had some time on the weekend. Anyway good luck.
Old May 2, 2005 | 03:20 PM
nocturnaldragon's Avatar
Default Re: Radiator fan inoperative (THugluv423)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THugluv423 &raquo;</TD></TR><TR><TD CLASS="quote">check relay. Put a jumper in between the plugs for the relay in the fuse box. There should be four diferent ones. Put the jumper in parallel pairs with two then try the other two. If the fan comes on It could be your relay.</TD></TR></TABLE>
This is the only good information in this thread.
But hes was just telling you how to jump the relay with the parallel pairs. I use a test light and check the connections that way to be sure the relay has constant power (For the motor) and a remote signal (Triggers the relay) and a good ground (For the coil on the relay to work) OTherwise my preferred way is to use an ohm meter. hit me up if you need clarification on anything!
Old May 2, 2005 | 03:35 PM
mechanix619's Avatar
Default Re: Radiator fan inoperative (nocternaldragon)
If you could post how to test a relay with a multimeter that would be hella sweet.
Old May 2, 2005 | 03:46 PM
99blackcivicSi's Avatar
Default Re: Radiator fan inoperative (smjensen)
depenidng on the relay being 1m 2m 1m-1b, or a 1t, there is diferant ways to check all of them, just because they click dosn't mean they work you have to check contenuity between them with a the ohm function on the DVOM (digital volt ohm meter), check for contenutiy between the control termanals and the switch side, usually if you have a service manual it will be in the beginning of the EL (electrical section) on how to test relays and which kind there are and so on and so forth, you can run a serach on here for who has the ESM's hosted for you to download, it will help you out a lot with how to do basic functions any more questions feel free to ask here or in PM
Old May 2, 2005 | 04:51 PM
Default Re: Radiator fan inoperative (99blackcivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi &raquo;</TD></TR><TR><TD CLASS="quote">depenidng on the relay being 1m 2m 1m-1b, or a 1t, there is diferant ways to check all of them, just because they click dosn't mean they work you have to check contenuity between them with a the ohm function on the DVOM (digital volt ohm meter), check for contenutiy between the control termanals and the switch side, usually if you have a service manual it will be in the beginning of the EL (electrical section) on how to test relays and which kind there are and so on and so forth, you can run a serach on here for who has the ESM's hosted for you to download, it will help you out a lot with how to do basic functions any more questions feel free to ask here or in PM </TD></TR></TABLE>
Thats EXACTLY WHAT I SAID, you just said it a whole lot longer with no help.
Ill look for a pic of a relay to show you how to test one.....
Old May 2, 2005 | 04:55 PM
There should be continunity between pins
85 & 86 (The coil)
30 & 87a (Normally closed)
With power to pin 85 and pin 86 grounded there should be continunity between pins
30 & 87 (Normally open)
Old May 2, 2005 | 08:22 PM
wo0t thanks for showing how to test relay. yoshi, i thin kthe engine coolant temp. swithc is the same thing as the fan switch . . . .not sure though but hte fan switch is the only senesoron the thermostat housing.
Old May 2, 2005 | 08:26 PM
rasinhell's Avatar
oh one time i thought my radiator fan wasn't coming on and I was making a big fuss about it. But it turned out to be because I wasn't waiting long enough for it to turn on.
Old May 2, 2005 | 08:40 PM
808_eG_unit's Avatar
just for a temp fix, take the plug and bridge the connection. the fan will run when the car is on and shut off when you turn the car off. but still fix the problem, this will get you along.
Old May 2, 2005 | 10:16 PM
Yoshiod9's Avatar
probably a stupid question but seeing as how i'd rather have this spelled out so i don't eff up my car...which plug are you referring to and how would i bridge the connection? i know how to hook the fan motor harness to a jumper wire and i think i'd be able to ghetto rig a rocker switch to fix the fan but i'd like clarification as to what you mean 808. thanks bro!
Old May 3, 2005 | 02:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocternaldragon &raquo;</TD></TR><TR><TD CLASS="quote">
Ill look for a pic of a relay to show you how to test one.....</TD></TR></TABLE>
considering i was writing mine the same time u were i just took a while to get it posted cuz i was on a 56k connection at the time, don't be such a smartass, before u jump to ****** conclusions
Old May 3, 2005 | 07:14 PM
Yoshiod9's Avatar
wow...so much animosity. lol. soooo...does anyone know how to answer the question i posed to 808?
Old May 5, 2005 | 12:48 PM
Mr. Samurai's Avatar
Default Re: (Yoshiod9)
I'm having the same problem, both hoses are HOT so my thermostat is working *at least i think it is* replaced the radiator switch, and when im at idle the needle will steadily increase and WILL overheat. fan simply isnt turning on. I'm real close to getting a new fan. I'm no good at electrical stuff but I'd like to test the relays and stuff before i get a new fan. i'm not even sure what to parallel or where to even look the fuse. I'm no good at electrical stuff.
Old May 5, 2005 | 02:52 PM
Default Re: (Mr. Samurai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Samurai &raquo;</TD></TR><TR><TD CLASS="quote">I'm having the same problem, both hoses are HOT so my thermostat is working *at least i think it is* replaced the radiator switch, and when im at idle the needle will steadily increase and WILL overheat. fan simply isnt turning on. I'm real close to getting a new fan. I'm no good at electrical stuff but I'd like to test the relays and stuff before i get a new fan. i'm not even sure what to parallel or where to even look the fuse. I'm no good at electrical stuff. </TD></TR></TABLE>
i belive there are two fuses, if its a 92-95 civic, there should be one fuse box tucked up above your gas pedal and stuff, a black box, second one should be in your engine bay beside the battery, theres diagrams on the fuse box covers to tell whitch fuse does what, so you'll be abel to find your fan fuse easily, take it out and theres a metal peice inside of it, if its not broken your fuse shoudl be fine, if its broken, replce and test it. remember to look at both fuses.
Old May 5, 2005 | 03:31 PM
Well if you want to be a dick you go ahead and help him dont let me hold you back, and I wasent being a smart ***. Youll know when im being a smart ***.
Old May 6, 2005 | 05:02 PM
Hey guys, I switched the ect radiator switch, swapped relays under the hood for another one, and the fan still isnt coming on. I tried looking for the underdash fuse but i couldnt find it. can anybody help me out on this one? Also is there a way i can wire up the fan to the battery so i can see if the motor is broken or not? thx. I have alligator clips and was thinking of doing it that way. O yea i forgot to mention i have a 2000 civic .
