things wrong with my crx
Old Apr 30, 2005 | 05:39 AM
e3suna's Avatar
Default things wrong with my crx
everything got changed out and shes running like a dream now. thanks guys!
Modified by e3suna at 10:22 PM 10/21/2005
Old Apr 30, 2005 | 01:18 PM
e3suna's Avatar
bump!
i need help!
Old Apr 30, 2005 | 01:56 PM
shawn_crx's Avatar
Default Re: (e3suna)
timing shouldn't be the problem. probably loosen alt. belt, buy a new one and slap it on. If you go to a shop they will rape you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">he patched it up</TD></TR></TABLE>
Never heard of patching a belt before.
Old Apr 30, 2005 | 03:38 PM
Styler93GSX's Avatar
Default Re: (shawn_crx)
I am almost 100% shure that your alternator is not charging. Take a DVOW and go across the battery termenals and see what the voltage is while the car is running. It should be abouve 12.6. The turn on your head lights and read the voltage again. If at either time they are below 12.6 volts your car is not chargeing. I'm not sure if on hondas they have an alternator fuse but check and see if they do if not the alternator needs replaced.
Old Apr 30, 2005 | 03:45 PM
e3suna's Avatar
by patching it up i meant he helped me get back on the road.
as in, fixed. sorry for the misleading use in words.
do alternator belts make a really high pitched screeching sound when you turn on your car?
thanks styler!
Old Apr 30, 2005 | 03:58 PM
definatly if the belt is loose. It needs to be tightened check to see if it has any cracks. Driving for so long the belt might have stretched a bit just tighten it up. After tightening I would definatly check the voltage though on your battery.
Old Apr 30, 2005 | 05:10 PM
da6jdmteg's Avatar
Default Re: things wrong with my crx (e3suna)
my old crx did that with my b16. and my problem was a small box on the back of the fuse box. i changed altenator cuz i thought that was wht the problem was and it was that box. i couldn't tell you what that box is called but thats what it was
civicegsick
Apr 21, 2013 01:40 PM
JDMgunmetalCRX
Apr 17, 2009 06:35 AM
maluseanjohn516
Jul 31, 2005 06:05 PM
KEVlN
Mar 15, 2003 12:27 PM
PPen131
Aug 31, 2002 08:01 PM
