crx electrical problem
ight check it i just had completed a full b16a swap on my crxabout a month ago. affter i took it out the shop i started to notice something wierd first when i hit the clutch the temp gauge woudl jump then as the weeks progress it go worse when i turn the lights on the blinkers would go on on the dash. then the fan stopped werking sumtimes and the gas gauge jumped up to full buy it self. now the car is at a point where it doesn't start and the light dun even come on and when i hit the hazards it make a buzzing sound..... now i looked all up and down this forum and found nuttin that can reall solve this problem only conlusion i came up with is that its a ground problem...... if any one know hit dis forum up cause i need answers!!!
did a shop do the swap for you? if so take it back becuase its obvious they did something...
From what you are telling me... some wires are grounding and shorting and touching eachother.. what model car did you get your motor put in too...
the wiring was definitly not done professionally
Sounds like the clutch switch isn't grounded properly and is instead grounding itself through other circuits. For sure, this is over your head, take it back to the shop.
Batterys probably dead if the main relay is buzzing like that. 11v+ makes it do that, jump the car with another battery WITHOUT that old battery in the loop. Take off the terminals and connect the pos/neg cables to jumper cables.
