How to tune your car faster !!
Old Apr 29, 2005 | 09:47 PM
Edward's Avatar
Default How to tune your car faster !!
My car is ITR. I did toda B cam, I/H/E, mugen head gasket and aftermarket cpu.
Now i am running 13-13.2 A/F ratio. If i put the a/f ratio more leaner, i will get more power. But the tuner said: it will destory your engine.
I saw he tuned B16A engine with the same A/F ratio as me or little bit learner than me. I would like to know, what is the range of A/F ratio for ITR is the best??
Old Apr 29, 2005 | 09:49 PM
RTW DC2R's Avatar
depends on the set up. low to mid 13s is probably pretty common and considered pretty safe as far as detonation goes (on a NA setup anyway). some cars like to run leaner, some like more fuel. u dont know til you get on a dyno with wideband and see what it likes. timing can also effect this. its better to stay safe rather than try to squeeze out 1more peak hp and get detonation.
Old Apr 29, 2005 | 09:55 PM
ZygSpeed's Avatar
Default Re: How to tune your car faster !! (Edward)
I'd say the tuner has done a good job for you by getting good power without putting your motor in danger.
Old Apr 30, 2005 | 12:20 AM
Edward's Avatar
Default Re: How to tune your car faster !! (zygspeed)
I want to try A/F ratio 13.5 from 2000rpm to 6000rpm and 13.3 from 6000rpm to 9000 rpm. Is it safety??
Old Apr 30, 2005 | 02:16 AM
RagingAngel's Avatar
The only way to determine if this is safe for YOUR motor is if your tuner is able to read signs of detonation on your sparkplugs.....
Some motors can handle it...while yours may not be able to....
Old Apr 30, 2005 | 03:04 AM
Pompiuses's Avatar
I'd say your AF is right on spot . Running it leaner will only gain a few hp, which you'll never notice anyway, while making your engine less reliable.
If you're beating on your R/going to trackdays, running rich will make your engine last longer due to lower combustion temp.
I say play it safe an keep it right where it is.
Old Apr 30, 2005 | 05:29 AM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Edward &raquo;</TD></TR><TR><TD CLASS="quote"> If i put the a/f ratio more leaner, i will get more power. But the tuner said: it will destory your engine.</TD></TR></TABLE>
You probably want to listen to the tuner.
On my last tuning, Sakai sacrificed about five horsepower because he knew that it would be on the track quite a bit, and he wanted it to last.
Old Apr 30, 2005 | 07:01 AM
SecretAgent's Avatar
also keep in mind that a/f ratio even a being a full point off, will not affect hp that much. your timing curve is the important, and riskier, one.
Old Apr 30, 2005 | 09:28 AM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Edward &raquo;</TD></TR><TR><TD CLASS="quote">My car is ITR. I did toda B cam, I/H/E, mugen head gasket and aftermarket cpu.
I saw he tuned B16A engine with the same A/F ratio as me or little bit learner than me. I would like to know, what is the range of A/F ratio for ITR is the best?? </TD></TR></TABLE>
theres more to tuning than just a/d ratio.. let it be.. so many get focused and facinated by peak numbers, what about reliability? don't you want your setup to last? its bad enough you got aftermarket camshaft, at least keep safe fuel settings
longetivity &gt; few more hp
P12 EG6
Dec 9, 2007 11:35 AM
22psicrx
Mar 19, 2007 06:18 AM
TwistedHatch
18
Sep 8, 2004 01:56 PM
DanishR
Aug 20, 2003 12:50 PM
oryanh
Nov 26, 2001 12:22 PM
