90 Accord Bad exhaust valve
Old Apr 29, 2005 | 08:19 PM
bear774's Avatar
Default 90 Accord Bad exhaust valve
I have a 90 accord with a bad exhaust valve. It is on the # 3 cylinder and, according to the leak down test is leaking down 90%. The strange thing is that it happened all of a sudden, one day the car ran fine then driving down the street it just lost a cylinder. Anyway just looking for input on how hard a head removal on this engine is. I have done it on a push rod engine but never one of these. Any advise is greatly appreciated.
Old Apr 29, 2005 | 10:46 PM
Nick H's Avatar
New User
Default Re: 90 Accord Bad exhaust valve (bear774)
removal of the engine is pretty straightforawrd and easy...as far as your leakdown, what were the compression numbers? also, do you know if the valve is bent or what? did your oil light come on or something? valves just don't bend for no reason...
Old Apr 29, 2005 | 11:26 PM
bear774's Avatar
Default Re: 90 Accord Bad exhaust valve (Nick H)
I don't know what the exact numbers on the leak down were, and I thought it was pretty odd for the valve to just all of a sudden bend or stop sealing for what ever reason. Thanks for the response.
Old Apr 29, 2005 | 11:27 PM
bear774's Avatar
almost forgot, no oil light or check engine light, just alot of smoke at higher rpms and a loss of power, as well as a strong smell of gas coming from the exhaust
Old Apr 30, 2005 | 12:10 AM
bear774's Avatar
also the speedometer is not working and has not been working for some time, is this a common problem in this car and is there a solution for it?
Old Apr 30, 2005 | 12:21 AM
Nick H's Avatar
New User
speedo is not a common problem, but it does happen...i highly doubt this is the cause of your problem however...did you over-rev the engine or anything at anytime? or float the valves ever? if so, this could have caused a bent valve...90% loss of the valve is quite a bit, though...make sure the valve head is not floating around in the combustion chamber...
Old Apr 30, 2005 | 07:53 AM
deserthonda's Avatar
if it is just a valve no need to rmove engine just remove cylinder head and do a valve job,,,
As for the speedo most likely you got a bad v.s.s (vehicle speed sensor) just the electrical part located in the tranny very common on those cars
Old Apr 30, 2005 | 09:03 AM
bear774's Avatar
Default Re: (deserthonda)
didn't over rev the engine, but it was driven literally by an old lady before me so i am assuming that the engine was never really reved (carbon build up maybe) anyway, does anyone have suggestions, or experiences with pulling the head on this car. As i said I have changed heads on push rod enginges but never an ohc, is it an extremely dificult procedure?
Old Apr 30, 2005 | 09:17 AM
Schmitey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">if it is just a valve no need to rmove engine just remove cylinder head and do a valve job,,,
As for the speedo most likely you got a bad v.s.s (vehicle speed sensor) just the electrical part located in the tranny very common on those cars </TD></TR></TABLE>
second that, don't know why you'd remove the engine for a valve job?!?
Old May 1, 2005 | 12:46 PM
bear774's Avatar
Default Re: (Schmitey)
bump for weekend advice on removing the head on my car
Old May 1, 2005 | 07:49 PM
Schmitey's Avatar
Default Re: (bear774)
buy a manual, if you don't have a solid walkthrough and diagrams you're gonna regret it!
Ehi
Feb 2, 2019 01:55 PM
TheSauce
Sep 24, 2012 03:47 PM
joetho
23
Dec 8, 2007 08:15 PM
LATINOSPEED
Aug 9, 2007 08:20 AM
Yuleluder
Aug 7, 2007 08:10 PM
