cel code 54crank fluctuation sensor WTF and 61 primary oxygen?
Can anyone tell me what code cel 54 CKF crank fluctuation sensor is about?
code 61? Where is the primary oxygen sensor on my car?
I should get a helms manual I know I know but any help is appreciated
Crank fluctioning sensor is down at the bottom by the crank pulley on the oil pump and ur primary oxygen sensor is on ur header. either they are bad or bad wiring.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98B00STED »</TD></TR><TR><TD CLASS="quote">Crank fluctioning sensor is down at the bottom by the crank pulley on the oil pump and ur primary oxygen sensor is on ur header. either they are bad or bad wiring.</TD></TR></TABLE>
what motor are you running?
saywhat
Dec 5, 2004 09:41 PM
