THROTTLE BODY TPS
Old Apr 29, 2005 | 05:41 PM
iLUVmyHONDAcura's Avatar
Default THROTTLE BODY TPS
my b18b1 tps was broken. my d16 has a tps that plugs up to the harness. will it work properly? i know i have to get it calibrated and all. but my question is will the d16 tps work on the b18b1 throttle body (plugs up to harness). thanks in advance guys.
Old Apr 29, 2005 | 05:54 PM
99blackcivicSi's Avatar
Default Re: THROTTLE BODY TPS (iLUVmyHONDAcura)
short and to the point yes
Old Apr 29, 2005 | 06:00 PM
Turbogixxer's Avatar
Default Re: THROTTLE BODY TPS (99blackcivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi &raquo;</TD></TR><TR><TD CLASS="quote">short and to the point yes </TD></TR></TABLE>
The man speaks the truth.
Old Apr 29, 2005 | 07:08 PM
thanks guys.
Old Apr 29, 2005 | 08:06 PM
civic_tuned's Avatar
Default Re: (iLUVmyHONDAcura)
yeah, ive heard that bseries and dseries are interchangable so that said "yes" it will fit! Just remember to calibrate it with a voltmeter and put it on 20dc's i believe. Next turn the ignition to "on" then just adjust the tps to close to .45 volts or 5 volts something like that!
Old Apr 30, 2005 | 12:23 PM
can anybody clarify on how to calibrate it? thanks civic type R but i want to know teh exact voltage and all that. your "something like that" made me unsure
Old Apr 30, 2005 | 02:14 PM
komat's Avatar
http://www.knology.net/~jediklc/tpshowto.htm
Old Apr 30, 2005 | 11:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iLUVmyHONDAcura &raquo;</TD></TR><TR><TD CLASS="quote">can anybody clarify on how to calibrate it? thanks civic type R but i want to know teh exact voltage and all that. your "something like that" made me unsure</TD></TR></TABLE>
1. u need a voltmeter
2. set it at 20dc's
3. u can connect it to your ecu or tps wiring green is negative and red is constant dont mess with the yellow one. Connect the - needle and puncture the green wire and the + needle to your red wire.
4. turn the ignition to on
5. move tps until close to 4.5volts
Old May 1, 2005 | 01:39 AM
nub.96ek's Avatar
Default Re: (civic_type_r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_type_r &raquo;</TD></TR><TR><TD CLASS="quote">
2. set it at 20dc's
5. move tps until close to 4.5volts</TD></TR></TABLE>
that should do it
turboef90
Mar 23, 2009 10:07 AM
xparalandrax
Oct 28, 2007 08:31 AM
endokun83
Mar 17, 2007 05:52 AM
gsrhb7
Northwest (Sales)
Mar 15, 2007 12:13 PM
ek_99_SiR
Jul 19, 2005 09:34 PM
