need info on ls swap into 91 crx
Old Apr 29, 2005 | 03:50 PM
TeamTorqueTeg's Avatar
Default need info on ls swap into 91 crx
i resently purchased a 91 crx hx, it has the single cam non vtec with an automatic trans. i also have a 91 teg which has a complete b-18a swap in it. well installing the engine isnt the problem, the problem is wid the wiring. i plan to use the PR4 ecu but when it comes to the wiring harness i'm lost. if i'm not mistakin the hx has only 2 injectors and the ls has 4 so i'm wondering if i should buy a harness from a company or will the stock ls wiring harness plug in . also will i need an adapter to put the PR4 ecu on the car. oh also i was wondering since i'm going from automatic to 5 speed will the gas/break/and clutch pedels from the ls bolt up in the crx. thanks
Old Apr 29, 2005 | 07:34 PM
shawn_crx's Avatar
Default Re: need info on ls swap into 91 crx (TeamTorqueTeg)
Wow. i haven't heard of HX CRX before. It must be a few made only.
Old Apr 30, 2005 | 05:06 AM
Default Re: need info on ls swap into 91 crx (shawn_crx)
my mistake, its an HF i hit the wrong key when i was typing.
Old Apr 30, 2005 | 05:08 AM
1RMDave's Avatar
Hf has 4 injectors like the Si so you are pretty much good to go. The stock integra harness will not plug in. But the pr4 ecu with clip right in with no mods.
thebornotaku
Sep 30, 2012 05:40 PM
jltucker31
Sep 25, 2009 03:54 PM
Forgotten4door
Jul 26, 2009 01:00 PM
BubbaDeuces
17
Feb 5, 2009 06:06 AM
T.Werd
Oct 11, 2001 07:35 PM
