d16z6 Into 88 CRX?
its never been done before. dont try it, it makes the car explode.
KIDDING!!!!!!!
its not hard and you should convert, it will be faster and properly use vtec.
you need a conversion harness from rywire.com or jkobd.com both honda-tech members, they will also help you if you get stuck.
im in the process of doing a mini me using a z6 head in a 1988 std hatchback right now. same wiring. if you have an SI or HF to start with, then you have MPFI which makes it easier.
KIDDING!!!!!!!
Civic Racer X 7
11
Apr 5, 2003 03:21 PM
