Thinking about purchasing a high compression b16, but want to increase to 1.8
Old Apr 29, 2005 | 12:38 PM
Jowee's Avatar
Default Thinking about purchasing a high compression b16, but want to increase to 1.8
I found a JDM B16a block with high compression aftermarket pistons and was thinking about picking it up for a project. I really can't stand the 1.6, so I was wondering if I could just put an LS or GSR crank in it to increase displacement to a 1.8. If I were to do that, what rods/bearings would I have to use?
TIA
Old Apr 29, 2005 | 01:23 PM
onepoint6i's Avatar
Default Re: Thinking about purchasing a high compression b16, but want to increase to 1.8 (ITR 98 1162)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR 98 1162 &raquo;</TD></TR><TR><TD CLASS="quote">I found a JDM B16a block with high compression aftermarket pistons and was thinking about picking it up for a project. I really can't stand the 1.6, so I was wondering if I could just put an LS or GSR crank in it to increase displacement to a 1.8. If I were to do that, what rods/bearings would I have to use?
TIA</TD></TR></TABLE>
you cant do that..you need custom pistons...i recomend just buying a one eight block and save the hassle...
Old Apr 29, 2005 | 02:13 PM
Used2beAb16's Avatar
look up b16 stroker kit on h-t and you will find your answers, you need custom pistions, but there are good ones out there.
Old Apr 29, 2005 | 09:18 PM
onepoint6i's Avatar
Default Re: Thinking about purchasing a high compression b16, but want to increase to 1.8 (Used2beAb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Used2beAb16 &raquo;</TD></TR><TR><TD CLASS="quote">look up b16 stroker kit on h-t and you will find your answers, you need custom pistions, but there are good ones out there.</TD></TR></TABLE>
nah..i would still go one eight block
Old Apr 30, 2005 | 12:40 PM
Default Re: Thinking about purchasing a high compression b16, but want to increase to 1.8 (1.6i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.6i &raquo;</TD></TR><TR><TD CLASS="quote">
nah..i would still go one eight block </TD></TR></TABLE>
Yeah your right, thats also what i did, but its totally not necessary.
Tech43 racing makes a great kit, look it up on H-T.
Old May 1, 2005 | 08:33 PM
onepoint6i's Avatar
LOL..I have it turn key right now runs hard still need to dyno though
Old May 1, 2005 | 08:38 PM
Kendall's Avatar
Well, you could run a B17 rotating assembly with 84mm sleeves and pistons and have your 1.8. Either way you're going to have to buy new pistons.
Old May 2, 2005 | 03:21 PM
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Well, you could run a B17 rotating assembly with 84mm sleeves and pistons and have your 1.8. Either way you're going to have to buy new pistons.</TD></TR></TABLE>
That would be a cool setup, and probably quite reliable, but i would be damned if i paid for sleeving to yield a 1.8 liter setup. If im paying for sleeves and going 84 or 85mm i would want a 2020 cc block
Old May 3, 2005 | 04:29 AM
Tex Blackwell's Avatar
Ide just move up to a 1.8 block then go from there.
7rrivera7
Jan 25, 2010 06:45 PM
93egSLEEPER
Dec 19, 2009 09:00 PM
cashshoes
18
Dec 15, 2006 09:12 AM
ensracer
Apr 14, 2004 07:45 PM
b16vtecsol
Jan 17, 2004 07:23 PM
