draining the block of water
Draining the radiator does not flush all of the coolant out.
If you want to do a complete flush, you will need to remove the large plug on the front of the block to drain it out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg »</TD></TR><TR><TD CLASS="quote">Draining the radiator does not flush all of the coolant out.
If you want to do a complete flush, you will need to remove the large plug on the front of the block to drain it out.</TD></TR></TABLE>
You could also probably remove a large portion of the coolant by removing the waterpump, thermostat housing, etc... When I did my waterpump, the radiator was fully drained, and when I removed the old pump, it spilled a shload of coolant...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4U2NV »</TD></TR><TR><TD CLASS="quote">
why do all that work when the drain plug is right on front of the block...
</TD></TR></TABLE>why do all that work when the drain plug is right on front of the block...
atikovi
Oct 7, 2010 05:49 PM
TypeRuz
Dec 5, 2003 09:15 PM
jdmspoonitr
Aug 1, 2002 02:00 PM
