where to get eye bolts with swivel
Old Apr 29, 2005 | 10:04 AM
VTIDelSol's Avatar
Default where to get eye bolts with swivel
Just seeing where i could these kind of bolts...i am thinking about making my own traction bars and want to have the movement in the supports.
Old Apr 29, 2005 | 10:08 AM
AceRaceParts's Avatar
Default Re: where to get eye bolts with swivel (VTIDelSol)
What size and type of material are you looking for?
Old Apr 29, 2005 | 01:27 PM
FormulaGSR's Avatar
Default Re: where to get eye bolts with swivel (mbpwrx)
i thibk what you are looking for is called a hiem joint
Old Apr 29, 2005 | 08:38 PM
blueoval557's Avatar
Default Re: where to get eye bolts with swivel (FormulaGSR)
yes, heim joint, or rod end. they come in aluminum, mild steel, and 4130 chrome-moly. what are you looking for exactly? for a typical traction bar, mild steel 1/2 inch rod ends/heim joints will be fine. good luck
kyle
Old May 1, 2005 | 02:59 PM
VTIDelSol's Avatar
Default Re: where to get eye bolts with swivel (blueoval557)
i didnt know the name of the part so my search for them was coming up with nothing. Any idea where a good place to get them would be?
Old May 2, 2005 | 07:44 AM
spiceisler's Avatar
Pegasus Auto Racing Supplies
Old May 2, 2005 | 08:09 AM
beepy's Avatar
Default Re: where to get eye bolts with swivel (clean90Si)
I think y'all would like this place better:
http://www.aedmotorsport.com/FK/CM_CF.htm
They sell FK rod ends, which come in a wide range of materials, metric sizes, and both left and right thread. If you need a size bigger than 12mm email dave@aedmotorsport.com, he can special order sizes up to 20mm.
You can't beat the price, and I like the metric thread. Some Kia guys have made adjustable panhard bars for our rear suspension, but they used standard SAE heim joints and had to have bushings machined. I just bought a RH 19mm and a LH 12mm heim, and an aluminum bar; drilled, tapped, and was done.
I think Honda guys will like the fact that they can use these joints with their OEM bolts.
Old May 3, 2005 | 11:20 PM
new2novas's Avatar
Default Re: where to get eye bolts with swivel (beepy)
also unless your planning on greasing them often, get a greasable set
Old May 4, 2005 | 02:49 PM
LBHgti's Avatar
Default Re: where to get eye bolts with swivel (new2novas)
mcmastercarr.com sells them I think
TracerAcer2.2L
Welding / Fabrication
Sep 18, 2015 10:44 AM
rick_rabies
Honda Fit
Aug 5, 2014 06:51 AM
gstrudler
Apr 19, 2012 09:39 PM
Knestis
28
Feb 16, 2006 06:47 PM
VtecBio009
12
Aug 31, 2004 10:48 AM
