Pass door lock just died...
Old Apr 29, 2005 | 09:39 AM
EnKidu's Avatar
Default Pass door lock just died...
it does not work via the power switch... is it the actuator or a fuse? Is there a fuse for one side or maybe a loose connection?
Old Apr 29, 2005 | 10:21 AM
AutoXer's Avatar
Default Re: Pass door lock just died... (EnKidu)
Check the fuse, then you'll have to pull the door panel to check for voltage at the regulator.
Old Apr 29, 2005 | 12:03 PM
EnKidu's Avatar
seems to work sometimes.... maybe its a connection huh??
Old Apr 29, 2005 | 12:37 PM
AutoXer's Avatar
Default Re: (EnKidu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnKidu &raquo;</TD></TR><TR><TD CLASS="quote">seems to work sometimes.... maybe its a connection huh??</TD></TR></TABLE>
Most likely. Pull the panel and see what you find.
motegicivic
27
Jan 19, 2015 11:03 AM
single_slam
Mar 6, 2012 10:34 PM
Blah.
Jan 1, 2011 05:33 PM
07FG2
Jan 16, 2009 04:39 AM
Strikerrr
Aug 22, 2005 10:09 PM
