Alternator Problem
Old Apr 29, 2005 | 07:26 AM
Homicide209's Avatar
Default Alternator Problem
This is the second time this has happened to me now, and it bothering the hell outta me. The top bolt that holds the alternator to the mount has fallen out again. I tightened this bitch down very very good, just yesterday it fell out while i was driving? Has anyone else had this problem. Its an LS swap in an EG. Please get back at me when you can. Thanks.
Old Apr 29, 2005 | 07:52 AM
Cuong-nutz's Avatar
Default Re: Alternator Problem (Homicide209)
have you tried using some thread lock? probably the threads are worn down/semi stripped causing them to loosen up.
Old Apr 29, 2005 | 08:07 AM
Lmgrcivic's Avatar
yeah either thread lock or get a new nut and bolt and try that it should work then
Old Apr 29, 2005 | 12:42 PM
Default Re: Alternator Problem (Lmgrcivic)
It was a brand new nut and bolt from acura, still it came off, i guess ill try the threadlock and see how that goes, thanks for the info fellas.
Old Apr 29, 2005 | 12:47 PM
shock_value's Avatar
Seems these people have the same problem, and have come up with a solution
Old Apr 30, 2005 | 01:29 AM
Default Re: Alternator Problem (shock_value)
Yah, hopefully it will work for me, its been nothin but problems since this swap went in. Clutch splines went out on me in 3000 miles, Constant oil leaks, think we found the problem to that, and this alternator problem. Hopefully we can get this thing all good so i can take it to the track. Thanks again everyone.
mr darcko
Jun 30, 2024 02:00 PM
efjones9
Oct 18, 2009 07:16 PM
Xuelor5
Mar 9, 2008 05:09 PM
