ABS Light: How to check what code it's throwing?
Old Apr 28, 2005 | 09:50 PM
OutlawCL's Avatar
Default ABS Light: How to check what code it's throwing?
My ABS light is on, how do I check which code it's throwing? I've searched and read around that it's kind of like checking the CEL, but how exactly do I check? I have an 97 Acura CL, but it's basically a rebadged 4th gen Accord. All my brake light bulbs are okay so that's not the problem. Thanks in advance.
Old Apr 29, 2005 | 04:05 PM
OutlawCL's Avatar
Default Re: ABS Light: How to check what code it's throwing? (OutlawCL)
Bump..anyone?
Old Apr 29, 2005 | 06:02 PM
Bishop Don Shizzle's Avatar
Oh yeah I forgot I can edit my own title! Yay!
Go to your local AutoZone. They'll check for free (most anyway).
Old Apr 29, 2005 | 11:17 PM
v4lu3s's Avatar
RTFM
same as the check engine light, once you jumper for the check engine light count the ABS blinks too.
Old Apr 30, 2005 | 01:30 AM
OutlawCL's Avatar
Default Re: (v4lu3s)
Ahh yes I read that somewhere and tried it. I don't have a CEL, but when I jumper it, the CEL comes on and stays solid, same with the ABS light. When I pull the paper clip out, CEL goes off, ABS stays on.
Old Apr 30, 2005 | 08:21 AM
jb.'s Avatar
jb.
Default Re: (OutlawCL)
on my 5th gen, the abs plug is right beside the check engine one under the glove box. it is the smaller of the two.
Old Apr 30, 2005 | 10:29 AM
v4lu3s's Avatar
RTFM
from a helm manual the scs mode method is:
connect the service conmnector, turn ignition switch on (do NOT have foot on brake), then it blinks to indicate teh codes, if theere is no code memorized the light goess off for 3.6 seconds thenc comes back on.
if the light for abs stays on but there is no error code:
possibke problems include: bad fuse, bad ground, short in power circuit to the abs conrtoller, loose connectors to teh abns controller, open in wire from abs controller to dash or a bad abs controller.
Old Apr 30, 2005 | 06:43 PM
OutlawCL's Avatar
Thanks v4lu3s for the help and for that 96 Prelude ECU you sold me a while back. I'll try this tomorrow.
Old May 1, 2005 | 08:37 AM
v4lu3s's Avatar
RTFM
no problem
I hope the procedure works, I know I hate trouble shootng ABS...
Old May 14, 2005 | 10:28 PM
OutlawCL's Avatar
Hmm, my dad has pretty much checked those problems but they're all good. He said he read some of the wiring diagrams, and saw that the ABS is somewhat connected to the cruise control? The cruise control is still sittin in the car but unconnected. Could this be it? Thanks.
Old May 15, 2005 | 04:59 AM
v4lu3s's Avatar
RTFM
if the abs troubleshooting section says teh ABS wotn work without the Cruise then id buy that.
shortlid
Mar 15, 2006 05:04 PM
Corporation
Aug 21, 2005 08:55 PM
2camsaam
Dec 7, 2003 12:19 PM
roadawg
Mar 5, 2003 03:37 PM
andrewasf77
Nov 26, 2002 09:19 AM
