anyone using 92-95 front shock forks on their sedan or hatch?
Old Apr 28, 2005 | 08:45 PM
TOMSBLUEHONDA23's Avatar
Default anyone using 92-95 front shock forks on their sedan or hatch?
i have a 91 sedan and i have 95 forks. whats needed to bolt these in? just the 95 shocks? because they are smaller so i would only need those right? thanks
Old May 1, 2005 | 04:31 AM
Default Re: anyone using 92-95 front shock forks on their sedan or hatch? (TOMSBLUEHONDA23)
bump!! anyone know?
Old May 1, 2005 | 04:51 AM
Sikocivic's Avatar
I have them on my 90 hatch. All you need is the 92-95 forks. Just bolts right in
Old May 1, 2005 | 04:55 AM
Default Re: anyone using 92-95 front shock forks on their sedan or hatch? (Sikocivic)
sweet thanks!! it make the car sit a little bit lower right?
Old May 1, 2005 | 07:52 AM
Louie B.'s Avatar
The 92-95 shocks have a larger diameter than the 88-91. The length of the fork is the same. I'm guessing if someone told you it would make the car lower it's because they're shoving the 88-91 shock further into the fork. You can do this trick with the 88-91 shock and 88-91 fork and gain about 1/4". I wouldn't recomend doing it with with 88-91 shocks and 92-95 forks though. it'd be too loose of a fit and could possibly pop out later causing all kinds of trouble. plus, if you shove the shock too far into the fork it's gonna rub on the axle shafts.
Old May 4, 2005 | 02:03 PM
ljoe's Avatar
if you decide not to use them, I NEED a set of them badly
Old May 4, 2005 | 07:14 PM
Default Re: anyone using 92-95 front shock forks on their sedan or hatch? (ljoe)
name a reasonable price and they're yours. email me at tomsbluehonda23@aol.com
Swansen
Apr 24, 2009 03:38 PM
Agent Daimon
Jan 3, 2007 06:22 PM
Azneita
Sep 21, 2005 07:01 PM
customx_
Oct 5, 2002 05:44 PM
