DIFFERENCES IN GT SERIES TURBOS VS T SERIES TURBOS
Old Apr 28, 2005 | 06:49 PM
Dragline's Avatar
Default DIFFERENCES IN GT SERIES TURBOS VS T SERIES TURBOS
Just would like to clarify what the differences are between these turbos.
Lets say a gt4067 vs a pt67
Old Apr 28, 2005 | 06:53 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: DIFFERENCES IN GT SERIES TURBOS VS T SERIES TURBOS (dragline)
the newer gt wheels are of a much better design... more aerodynamic and flow much better.. which pretty much means more power at lower boost levels and quicker spool.
Old Apr 28, 2005 | 07:33 PM
Dragline's Avatar
Default Re: DIFFERENCES IN GT SERIES TURBOS VS T SERIES TURBOS (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">the newer gt wheels are of a much better design... more aerodynamic and flow much better.. which pretty much means more power at lower boost levels and quicker spool.</TD></TR></TABLE>
So are the housings the same or different also?
Old Apr 28, 2005 | 07:47 PM
wantboost's Avatar
Who is Mr Robot?
if i remember correctly, they are the same as the old ones.. although the 4-bolt housings are the newer design
Old Apr 28, 2005 | 07:55 PM
Dragline's Avatar
So you can run a gt wheel in a quote t-series turbo then?
Old Apr 29, 2005 | 05:18 AM
Dragline's Avatar
bump for more info.
Old Apr 29, 2005 | 05:19 AM
b18bturbo's Avatar
no you cant run a GT wheel in ptrim housing most of the older turbos were running p trim wheels as well as o trim turbines. The housings are just too small for the newer GTQ and GTS wheels that are on the market
but remember you can machine any housing to fit any wheel as long as it withing a given spec.
Old Apr 29, 2005 | 06:20 AM
Dragline's Avatar
Default Re: DIFFERENCES IN GT SERIES TURBOS VS T SERIES TURBOS (b18bturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">no you cant run a GT wheel in ptrim housing most of the older turbos were running p trim wheels as well as o trim turbines. The housings are just too small for the newer GTQ and GTS wheels that are on the market
but remember you can machine any housing to fit any wheel as long as it withing a given spec.</TD></TR></TABLE>
So are they machining the housings on the pt67 because you can get it with the gts or gtq wheels,just trying to figure what the big difference is if they offer the same wheels.
Old Apr 29, 2005 | 06:24 AM
b18bturbo's Avatar
its all based on which exhaust wheel you want the housing they use is machined for whatever you want. GTQ is what is most popular right now
Old Apr 29, 2005 | 06:32 AM
Dragline's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">its all based on which exhaust wheel you want the housing they use is machined for whatever you want. GTQ is what is most popular right now </TD></TR></TABLE>
So my ? is what would be my advatage of get a GT turbo then just say a pt
Old Apr 29, 2005 | 06:37 AM
b18bturbo's Avatar
the wheel design like stated above the P trim is 70 technology where the wheel angles and all were designed not for performance but rather for diesel use which is where turbos got there start from.
The new designed GT wheels are far superior in design and can flow alot more air compared to the others.
JadedGamerX's Avatar
Faster spool, more peak boost, he already explained it.
Old Apr 29, 2005 | 06:44 AM
Dragline's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">the wheel design like stated above the P trim is 70 technology where the wheel angles and all were designed not for performance but rather for diesel use which is where turbos got there start from.
The new designed GT wheels are far superior in design and can flow alot more air compared to the others. </TD></TR></TABLE>
I know what your saying but my ? is if I can get the pt67 with a GTS or GTQ wheel what is my differents then if I was to get a gt4067 with the same wheels,or am I miss something here that your saying.
Old Apr 29, 2005 | 06:50 AM
b18bturbo's Avatar
the gt4067 is different turbo than a pt67 with gtq turbine
we are talking turbine trims here not compressor tthats probably what is confusing you.
Old Apr 29, 2005 | 07:21 AM
Dragline's Avatar
I was confused alright what does the 40 stand for then?
Old Apr 29, 2005 | 08:46 AM
wantboost's Avatar
Who is Mr Robot?
gt40 exhaust side... with a 67mm compressor side
Old Apr 29, 2005 | 11:57 PM
Arturbo's Avatar
Better than steak
25 Year Member
You guys are making it a lot harder than it really is.
spoolin turbo s
Mar 4, 2008 03:46 PM
bboixtc
Nov 30, 2006 03:09 PM
Evo-man@20psi
32
Mar 28, 2005 02:53 PM
15psi of fun
Nov 5, 2004 09:41 AM
tegasaurus
Sep 10, 2003 09:17 AM
