???? about coilovers
Old Apr 28, 2005 | 06:18 PM
impr323's Avatar
Default ???? about coilovers
OK I know this is a dumb question but here it goes, I have skunk2 coilovers and im trying to make the ride height as stock as possible. Is there any measurments that anoyone has for this??? Also how do I keep the whole assembly from turning while im tightening the upper sleeve???Finaly, a real dumb question, is it normal for the spring to just dangle there after you lower the sleeves a beyond a certain point. Im supposed to have pressure on the spring with sleeves before I lower the jack correct ???? Just learning guys, thanks!!!
Old Apr 28, 2005 | 06:26 PM
civictildeath's Avatar
Default Re: ???? about coilovers (impr323)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by impr323 &raquo;</TD></TR><TR><TD CLASS="quote">is it normal for the spring to just dangle there after you lower the sleeves a beyond a certain point.</TD></TR></TABLE>
it does that when the shock is compressed all the way which means you lowered it too far
measurements of what?? stock from top of hubcap to bottom of fender on EK with 14" wheels is around 6 1/2"
lowtegsr
Suspension & Brakes
10
Jun 10, 2008 02:55 PM
suno
Suspension & Brakes
Apr 16, 2008 06:08 PM
Teglessb18
Suspension & Brakes
Feb 9, 2006 10:29 AM
GroundZer0 336
May 5, 2005 12:20 PM
aznfab
Oct 22, 2003 12:39 PM
