What is this part called?
the one pictured is one off a EG but I think I need one off a DC2 Integra in order to make the horn/airbag work on my JDM ITR SRS STEERING WHEEL. Please correct me if I am wrong.
Helm refers to it as the SRS Cable Reel. The little black connector is for the horn. If there was a slightly larger connecter that was not yellow itd be for the Cruise Control, but the Rs dont have it
thanks. one more question...so will i need one off a dc2 in order for me to hook up the horn/airbag to my EG? or would I be able just to use this EG one and hook up the horn/airbag on my jdm itr srs steering wheel?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by *****StEr »</TD></TR><TR><TD CLASS="quote">thanks. one more question...so will i need one off a dc2 in order for me to hook up the horn/airbag to my EG? or would I be able just to use this EG one and hook up the horn/airbag on my jdm itr srs steering wheel?
I can't answer that one. Might want to try the EG+ forum.
The above picture is a clock spring and you will be able to plug the horn in on the existing plug but the airbag will not plug in. I put the jdm srs itr wheel on a friend of mine's 92 vx hatch and the airbag plugs were different but other models/years may vary.
As far as the plugs that go into the airbag assembly itself you will need a clockspring from a 98+ DC2 integra. I am not sure if the plug that hooks into the chassis harness (ie. one that goes under column) is the same but I know for a fact that the one on the airbag end is correct off of the car listed above. If you need one of the dc2 clock springs shoot me a pm I should have one here...
ek9dc2
Jul 15, 2006 12:08 PM
Bay_707
Jun 30, 2004 04:41 PM
DarkCyde SI
Sep 3, 2003 07:52 AM
[Caster]
May 30, 2003 05:45 AM
