Fidanza Lightweight Flywheel Torque Specs
Old Apr 28, 2005 | 04:29 PM
madswapper's Avatar
Default Fidanza Lightweight Flywheel Torque Specs
I could really use the crank bolts and pressure plate bolts torque specs for a Fidanza flywheel part#191161. The wheel came with an instruction sheet but the actual part # for my flywheel was not on the section about torque. The flywheel is for a D16z6 and I am dropping it in tonight. This is the only thing I am not sure about as of right now. thx peace.
Old Apr 28, 2005 | 04:47 PM
dr_latino999's Avatar
Default Re: Fidanza Lightweight Flywheel Torque Specs (madswapper)
Torque specs are the same as stock.
Flywheel --> Crank - 87 ft/lbs
PP --> Flywheel - 19 ft/lbs
Old Apr 28, 2005 | 05:19 PM
madswapper's Avatar
Default Re: Fidanza Lightweight Flywheel Torque Specs (dr_latino999)
I was just under the impression that aluminum flywheel's had to be torqued higher than steel flywheel because of the expansion factor, but i will take your word for it.
thx man
Old Apr 28, 2005 | 05:24 PM
tc_gts's Avatar
lolz for your information aluminum is a great dispenser of heat...so they dont expand and contract as much as you would think... plus its much softer metal so if anything the torque would be less... believe me ive gone to school they teach you all of this...
Old Apr 28, 2005 | 06:10 PM
madswapper's Avatar
Default Re: Fidanza Lightweight Flywheel Torque Specs (tc_gts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tc_gts &raquo;</TD></TR><TR><TD CLASS="quote">lolz for your information aluminum is a great dispenser of heat...so they dont expand and contract as much as you would think... plus its much softer metal so if anything the torque would be less... believe me ive gone to school they teach you all of this...</TD></TR></TABLE>
Let me show you something about learning son.
from the Fidanza Aluminum Flywheel Instructions <U>and I quote</U>.
"Aluminum expands at twice the rate of steel so that in order to retain a tight fit when the engine and flywheel gets hot - the aluminum flywheel has to go on tighter at ambient tempetures for a proper tight fit at running tempatures."
I am still not certain and would like to listen to anyone with an answer to my question concerning aluminum vs. steel flywheels.
Why would Fidanza have this in their instructions if the flywheel only needs spec torque (87ft/lbs)?
*EDITS TC_GTS GOTZ PWND!!!115UCK3R
Modified by madswapper at 5:59 PM 5/1/2005
Old May 1, 2005 | 05:01 PM
madswapper's Avatar
we have the motor in and are still waiting for one part but I am still uncertain about the torque specs as in my last post.^^^
hit me back plz. thx peace.
Jk_DC2
Feb 17, 2009 10:40 AM
AllMoToRB18c
Sep 23, 2003 10:00 PM
AllMoToRB18c
Jun 29, 2003 11:24 PM
