need some advise from ya expert
Old Apr 28, 2005 | 04:11 PM
1990hf's Avatar
Default need some advise from ya expert
i bought a 88 CRX SI from this guy for 7 bills but he said somethings wrong with the motor. he was at work one day and start redlining the car 4 time on neutral and on the fourth time the motor went puff. he said the car will start but it wont go over 2 1/2k RPM. need alot of help here.
THANKS.
Old Apr 28, 2005 | 04:14 PM
ServiceAdvisor's Avatar
Well for $700, if the chasis is straight, and the interior is decent its a steal. Remember, you can find another motor and swap it yourself for less than $400. Also its an Si :D - Darrell
Old Apr 28, 2005 | 04:17 PM
dr_latino999's Avatar
Default Re: (DOHCZCCRXSi)
Sounds like
1) Broke the timing belt
2) Floated a valve or two
3) Blew a rod or four
4) Had massive bottom end failure
Any if not all of the above.
Old Apr 28, 2005 | 04:30 PM
UltimX's Avatar
Default Re: (dr_latino999)
broken timing belt wouldn't be able to start the car.
Old Apr 28, 2005 | 04:33 PM
kaoss_11's Avatar
B A N N E D
dr i choose 2
Default Re: (UltimX)
Ok, let me rephrase.
Skipped timing belt resulting in but not limited to any of the following -
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like
Any if not all of the above.</TD></TR></TABLE>
Old Apr 28, 2005 | 04:39 PM
1990hf's Avatar
no rust on the body and the interior is really in good condition
Old Apr 28, 2005 | 04:40 PM
1990hf's Avatar
well hope i can figure out wats wrong with the motor cuz i just sold my Y8 to my boy.
Thanks for the help.
Old Apr 28, 2005 | 04:43 PM
Default Re: need some advise from ya expert (1990hf)
Do a leakdown test and a compression test, and if you get odd readings pop that head and give the internals a look.
Old Apr 28, 2005 | 04:45 PM
1990hf's Avatar
thanks
Old Apr 28, 2005 | 05:00 PM
d16efsedan's Avatar
Default Re: (1990hf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990hf &raquo;</TD></TR><TR><TD CLASS="quote">no rust on the body and the interior is really in good condition</TD></TR></TABLE> wow for a michigan car thats a hell of a deal ,i used to live in michigan and could never find any without rust......
Old Apr 29, 2005 | 09:57 AM
1990hf's Avatar
Default Re: (d16efhatch)
i know, i was pretty surprise myself and its not bondo either cause i did the magnet test.
Old Apr 29, 2005 | 11:09 AM
hahagasdcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990hf &raquo;</TD></TR><TR><TD CLASS="quote">i bought a 88 CRX SI from this guy for 7 bills but he said somethings wrong with the motor. he was at work one day and start redlining the car 4 time on neutral and on the fourth time the motor went puff. he said the car will start but it wont go over 2 1/2k RPM. need alot of help here.
THANKS.</TD></TR></TABLE>
Borrow a friends distributor and see if that helps. If you have a code 8 or 9 that will keep your car from going over 3k rpm.
Old May 2, 2005 | 08:16 AM
1990hf's Avatar
Default Re: need some advise from ya expert (hahagasdcrx)
the guy said theres nothing wrong with the distributor but i'll check it again myself
thanks
Old May 2, 2005 | 10:51 AM
89Si's Avatar
look at the front of the block for a 2.5" diameter hole and oil shooting from it. oh wait, that was my buddies hatch when he revved his engine to like 13k. i should dig the video camera up and upload that somewhere. haha. but seriously, sounds like you blew a rod to me, just like what his car did.
Old May 3, 2005 | 11:25 AM
1990hf's Avatar
got the car running normal. the guy blew the head gasket so i just put a new gasket and my 89 si head on it.
thanks every one for helping out.
H22CD7
Jul 18, 2007 08:11 PM
ThePunk
Jan 18, 2007 01:46 AM
djtony5
May 5, 2006 09:52 PM
s8an
Aug 6, 2004 11:16 PM
llW0PllNefRex
Aug 3, 2003 08:10 PM
