Mini me help....
Old Apr 28, 2005 | 01:48 PM
Otherguy's Avatar
NASIOC.com
Default Mini me help....
Why does my timing belt whine so much? im using a y8 head and d15b7 block...
Old Apr 28, 2005 | 01:59 PM
honda_civic1's Avatar
Default Re: Mini me help.... (Otherguy)
just check your timing? i also did a mini swap to mine and it works just fine
Old Apr 28, 2005 | 02:06 PM
Otherguy's Avatar
NASIOC.com
Default Re: Mini me help.... (honda_civic1)
Well what belt am i spose to use? i got a z6 belt for the job... is that tooo tight? or do i need to use the 96 ex belt that came with the y8
Old Apr 28, 2005 | 02:50 PM
delslo93's Avatar
Yes the z6 belt it what u need....When i did mine it winned for a bit too. Mine was pretty damn tight and took a lot to get it on the cam gear but it will loosen up over time.
Old Apr 28, 2005 | 02:55 PM
Otherguy's Avatar
NASIOC.com
Default Re: Mini me help.... (delslo93)
some people are saying that i need to us the 96 ex belt since the cam gears are diff from the 92-95 compaired to the 96-98
Old Apr 28, 2005 | 10:57 PM
Ignitecivic's Avatar
get the belt for the head
Old Apr 29, 2005 | 03:35 AM
JAMinCiViC's Avatar
Default Re: Mini me help.... (Ignitecivic)
i did a a6/y8 minime. I used the y8 timing belt and no whine
Old Apr 29, 2005 | 04:06 AM
93b20z's Avatar
why use a d15 block??.. high compression??.. thats what i was using but what is so good about it??.. what potential does a minime swap have over z6...?? j/w
Old Apr 29, 2005 | 10:54 AM
Otherguy's Avatar
NASIOC.com
Default Re: (hmongyaj7)
is the y8 belt 105 teeth? compaired to the z6 that has only 104?
Old Apr 29, 2005 | 10:55 AM
POE's Avatar
POE
i belive its only 104.
Old Apr 29, 2005 | 01:20 PM
Otherguy's Avatar
NASIOC.com
Default Re: (POE)
so they are the same?
byrne_06
10
Aug 3, 2010 12:56 PM
johnwohl
Nov 9, 2008 04:51 AM
blinger
Jul 22, 2007 04:33 PM
blindoboy87
11
May 19, 2006 05:57 AM
SOHC_MShue
15
Jun 3, 2005 06:18 PM
