Rack and Pinion or what?!!?!?
Old Apr 28, 2005 | 12:31 PM
jdmazm's Avatar
Default Rack and Pinion or what?!!?!?
Ok here is the situation, whenever I turn left or right the car gives like a rolling sound, almost as if the axles were bad (not clicking) Its so freeakkingg loud its like roll roll roll roll. But i checked the axles and everything was A OK, no cuts in the CV boot, it was seated properly. The person who had the car before told me he changed the "Drive Pinion" whatever that is, i think he meant rack and pinion. The axles are not the problem, anyone know what it is?! It feels as if my wheels are going to fall off.
Old Apr 28, 2005 | 12:40 PM
dr_latino999's Avatar
Default Re: Rack and Pinion or what?!!?!? (jdmazm)
Possible bad wheel bearings.
Old Apr 28, 2005 | 12:45 PM
Tyson's Avatar
what does a rolling sound sound like?
jack the car up, rotate the wheel. listen/feel for a rumble to check for bad wheel bearing.
drive pinion sounds like he meant the outer CV joint.
Old Apr 28, 2005 | 07:53 PM
jdmazm's Avatar
Default Re: Rack and Pinion or what?!!?!? (Tyson)
if it wasn't my wheel bearings, you think it could be just as simple as getting my wheels balanced?
Old Apr 28, 2005 | 07:57 PM
Tyson's Avatar
balancing your wheel doesnt have anything to do with a noise.
if its not your axle or wheel bearing, sorry im out of guesses.
88aeFC3S
Sep 4, 2010 10:35 PM
jdmeg9
Nov 29, 2005 09:58 AM
pdc125
Jul 27, 2005 07:27 AM
fe519
May 19, 2003 07:29 PM
Rain_man
Jun 21, 2001 10:21 PM
