wheel knocking
Old Sep 4, 2010 | 04:37 PM
88aeFC3S's Avatar
Default wheel knocking
what would cause my front driver side wheel to make a knocking sound while rolling in neutral? the sound is coming from the front driver side. it only makes the sound while im rolling in neutral or rolling while i hold the clutch down but not when i give it gas or press the brakes.
im thinking maybe my wheel bearing is going out or the axles...
Old Sep 4, 2010 | 04:48 PM
88aeFC3S's Avatar
Default Re: wheel knocking
just talked with my buddy, he said that if it was a bad wheel bearing then it should be knocking or clicking all the time, not just when im rolling in neutral or holding the clutch down.
so maybe cancel out that the problem being my wheel bearing?
Old Sep 4, 2010 | 04:56 PM
jetspeedz's Avatar
clicking is usually axles, i just replaced my bearings if its bearings the sound will get worse the faster you go and you can see if there is play by jacking up the car and see if there is play when you put pressure on it from 6 and 12.
Old Sep 4, 2010 | 05:01 PM
88aeFC3S's Avatar
its more of a knocking sound than a clicking sound. i can kinda feel it knocking under my foot on the clutch pedal as it makes the sound.
Old Sep 4, 2010 | 05:30 PM
JDM215's Avatar
kind of sounds like a problem im having..
Old Sep 4, 2010 | 05:37 PM
88aeFC3S's Avatar
a buddy of mine said that it could be a bad or sloppy U joint, possible endplay/more clearance than its supposed to (would explain no-load knocking)
Old Sep 4, 2010 | 10:35 PM
speed_racer012's Avatar
sounds like an axle.
Mel M
Transmission & Drivetrain
Aug 20, 2010 09:53 PM
dRuNkEnMoNkEy97
Sep 27, 2006 08:56 PM
jdmeg9
Nov 29, 2005 09:58 AM
fe519
May 19, 2003 07:29 PM
Rain_man
Jun 21, 2001 10:21 PM
