Plug wires?
What do you all think of MSD plugwires. They showed that theyre only 8.5 mm whereas other companies are going a lot bigger and didnt knwo what you all recommended? Cant afford Nology so i want to go the best i can for around 50-60 bux hopefully.
no ****? even with denso iridium plugs youd still say that the NGK would get the best fire? would you say if i was gonna do the ignition pack and coul to then go with msd or stick with NGM all around?
Well switch out the Denso plugs for starters, go back to NGK plugs as well. I wouldn't even really worry about ignition upgrades, many high HP setups are running the stock ignition still.
