O2 wiring help on B18C SIR-G
Old Apr 28, 2005 | 09:47 AM
CivicHB93JDM's Avatar
Default O2 wiring help on B18C SIR-G
Hello everyone, I just have a quick question regarding the 02 sensor wiring from a B18C Sir-G engine to the ecu. Requires 4 wires. Does anyone know the punch code on the ecu for these wire. I'd search everywhere. thanks.
Old Apr 28, 2005 | 09:54 AM
Luserkid's Avatar
Default Re: O2 wiring help on B18C SIR-G (CivicHB93JDM)
What motor is this going in?
Old Apr 28, 2005 | 10:05 AM
Default Re: O2 wiring help on B18C SIR-G (Luserkid)
it's going into a 93 civic hatch cx
Old Apr 28, 2005 | 10:12 AM
Luserkid's Avatar
CX, thats 1 wire (white) o2 sensor right?
This is what you do, you have a 4 wire o2 from the GSR right? 2 blk, 1 white, 1 grey?
Should look like this:
This is where they go:
black - Heater control - A6 ECU - only wire to run through firewall.
green - O2 ground - splice into one of the black wires that runs to the thermostat housing.
white - O2 signal - use existing sheilded O2 wire to D14
black - heater power - power from C125 (large group of yel/blk wires)
More info here:
https://honda-tech.com/zerothread?id=1180819
Old Apr 28, 2005 | 10:52 AM
Thank you. this will help.
91efbluehatch
13
Nov 7, 2012 06:21 AM
Iron_Forrix
Jan 11, 2007 06:57 PM
japish
Aug 8, 2006 10:44 PM
vladd
Dec 5, 2003 08:42 PM
