KYB AGX adjustments 4 or 8 way??????
I know this wasy probably covered a million times and i did search and looked around elsewhere on the internet but.....
Are the KYB AGXs' for the 96-00 civics 4-way adjustable or 8-way adjustable???? I keep seeing people say both so i'm confused as to what they really are.
Thanks for any info!!!!
it depends on if you talk front or rears, as they both have a different # of adjustments. I believe the rears are 8 and fronts are 4
the front should be a dial at the top and the rear has a **** on the side which you gotta reach other and yea its 4 on front and 8 in rear. i have hatchback maybe its different for different models..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by handa »</TD></TR><TR><TD CLASS="quote">mine is 4 in the front and 4 in the back. did i get the wrong one?</TD></TR></TABLE>
Do you have an EG? I've heard they only have 4 adjustments on each corner, while the EKs have 4/8 f/r.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D50boy »</TD></TR><TR><TD CLASS="quote">4F and 8R
FYI, i got this info from KYB about a month ago when i bought my shocks...
The AGX products have the following approximate damping force values.
When adjusted, both rebound and compression damping forces change.
Setting#:
Relative Value
1 - Same as Factory 100
2 - Same as our GR2 products (10~15% firmer than Factory) 115
3 - 50% firmer than #2 172
4 - 30% firmer than #3 223
For an eight position adjustable product, the damping force values are
approx.
the following:
With #2 being Factory at a relative value of 100,
#1 = 95 (5% softer than Factory #5 = 143.5 (43.5% firmer
than Factory)
#2 = 100 (Factory damping force) #6 = 172 (72% firmer
than Factory)
#3 = 107.5 (7.5% firmer than Factory) #7 = 197.5 (97.5 firmer
than Factory)
#4 = 115 (15% firmer than Factory)(GR-2) #8 = 223 (123 % firmer
than Factory)
Setting#:
Relative Value
approx.
the following:
than Factory)
than Factory)
than Factory)
than Factory)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-RO »</TD></TR><TR><TD CLASS="quote">FYI, i got this info from KYB about a month ago when i bought my shocks...
Setting#:
Relative Value
approx.
the following:
than Factory)
than Factory)
than Factory)
than Factory) </TD></TR></TABLE>
Great Info!!!!!
Setting#:
Relative Value
approx.
the following:
than Factory)
than Factory)
than Factory)
Great Info!!!!!
