Can ITR valvesprings be used with Zex street/strip cams?
I did a search on ITR valvesprings and did not find any specs. So this is from Zex's web site
Superclean chrome silicon wire
0.896" Outside Diameter / 0.600" inside diameter
Installed 50lbs. @ 1.950" / Open 170 lbs @ 1.450"
Spring rate 240 lbs./in.
Coil bind height 1.360"
Single spring coil for both intake and exhaust
I am planning to use Zex's street/strip cams in my head do I need to get Zex's valvesprings or can I use ITR. Here is a link to Zex's cam specs. http://www.compcams.com/catalog/192_193.html
Thanks for any help
[Modified by NC-B17A, 12:16 PM 2/1/2002]
Thanks for any help
Your gonna tell me that out of 35 people looking at this the only person to reply is a 12 year old.
If some one could please just tell me where to find some info on the ITR valvesprings then I could figure it out.
hey,don't i know you?i'm not sure.i would just use the zex springs with their cams,or itr springs with it's cams.they were made to work with each other.i talked to gary today at pelham auto machine.i warned him that you would be coming to see him.he said that it would be a piece of cake.i let him know yuo are kind of **** to give him a heads up.ha!ha!
cjames235
Jan 17, 2004 08:14 AM
