timing belt upgrade
if i go with buddy club b-series adj cam gears should i also upgrade timing belt or is it safe to stay oem. this is my daily driver and will be for awhile so i need it to be very reliable. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 510gserhatch »</TD></TR><TR><TD CLASS="quote">if i go with buddy club b-series adj cam gears should i also upgrade timing belt or is it safe to stay oem. this is my daily driver and will be for awhile so i need it to be very reliable. thanks </TD></TR></TABLE>
Stay with the OEM Honda Belt.
I have used the Toda belt on 3 different motors. They are stronger then stock. The problem that I have seen is on all three motors the belt didnt last past 20k miles.
My OEM had 85k and look great. So after two heads with bent valves I went back to OEM. The other motor, I pulled the belt and the ribs were cracking.
If you are building a full race motor
but replace it often.
Street driven stay with the OEM belt.
but replace it often.Street driven stay with the OEM belt.
