bad vibration in b16-->89 CRX dx swap
Old Apr 27, 2005 | 08:28 PM
bob06's Avatar
Default bad vibration in b16-->89 CRX dx swap
I have a really bad vibration that shakes the whole car any time abovr 40mph. It is worse when i turn right and lets off some when i turn left. It does it during accelaration and gets noticably worse around 40mph, it also does it during braking untill i get down to about 10 mph. it always does it turning right if i'm going above about 15mph. Could the axle be the problem? or is it something else?
Old Apr 27, 2005 | 09:01 PM
Super79Dave's Avatar
Default Re: bad vibration in b16-->89 CRX dx swap (bob06)
I'M THINKIN AXLE
Old Apr 27, 2005 | 09:04 PM
ACRProject's Avatar
Default Re: bad vibration in b16-->89 CRX dx swap (Super79Dave)
i am thinking the same, which axles are you running?
Old Apr 27, 2005 | 09:08 PM
turboJDMeg6's Avatar
hmm i have the same problem too! but not wen accerlating or turning only wen i brake like he said, its vibrates big time! like the wheel or car is going to fall apart on me. i broke the passenger side axle before and i replaced it with a 90 integra ls axle with abs ring. could that be the problem?
Old Apr 28, 2005 | 06:10 AM
slow91crx's Avatar
Default Re: bad vibration in b16-->89 CRX dx swap (91b16ef9)
i say axle, there is not alot of other things it can be really.
Old Apr 28, 2005 | 07:24 AM
bagpipe goatee's Avatar
axles, spindles, alignment, wheel bearings, balljoint and bushings (i guess these fit in with alignment)
you didn't change the spindles out did you?
another common problem is axle binding with cheap motormounts.
Old Apr 28, 2005 | 09:26 AM
slow91crx's Avatar
Default Re: (bagpipe goatee)
we put the car up on blocks in my shop with wheels off and got it to about 50 and nothing shaked noticeably, axle looked fine. this is a vibration alot worse than that of poor alignment from what i have seen and felt with it. and he has hasport mounts so binding is not an issue, the motor is solid. not tryin to jack the thread, im just puttin the info out there to help him get some answers.
Old Apr 28, 2005 | 09:41 AM
hybridmiklo's Avatar
Default Re: (slow91crx)
IT's probably your axles. But for the guy who hits his brakes and its all bad. Those are your rotors. THey are warped.
Old Apr 28, 2005 | 08:32 PM
yeah, your axles could be binding or something, where it only comes into play when the suspension is at a certain height...
Old Apr 28, 2005 | 08:40 PM
bob06's Avatar
I did lower the car on some $53.98 ebay special "JDM red" coil overs on stock shocks. It isn't dumped but it is lowered about 1.5 - 2 inches. Could this cause the axle to bind. I will look tomorrow at how the axle sits. It would be binding if the axle was straight out with no play right?
Old Apr 30, 2005 | 08:26 AM
bob06's Avatar
Default Re: (bob06)
bump, i really need some help on this issue. i have no idea what it could be. I tightened everything and have taken both axles out and they both seem fine. It's not the wheels or tires because it did the same thing with a different set of rims...
Old May 1, 2005 | 10:10 AM
sorry, didn't read that you had the hasport mounts.
assuming you have the hasport mounts and the right axles (90-93 teg) there will be no binding
i have another idea, is a lower control arm bent? i've seen that before, so it has to be at least kinda common if the previous owner (or maybe you? heh, jk) drove the car like an ***.
crxgsrsi
20
Dec 16, 2013 11:09 AM
t3601
Transmission & Drivetrain
Dec 3, 2009 01:53 PM
JDM_LS
Jun 28, 2008 09:34 PM
ocram
Oct 13, 2004 04:17 PM
Fooman
Jun 3, 2002 09:14 PM
