skunk2 stage 2 recommendation
I'm puttin in stage 2, I'm tryin to figire out which pistons should i order, p30 or ctr...can you guys help out? or recommend somethin else.Also with the aem tru time cam gears with 3 nuts hold it. I heard stories where they slip, is that true?
Modified by aznstyler119 at 5:27 AM 4/28/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznstyler119 »</TD></TR><TR><TD CLASS="quote">I'm puttin in stage 2, I'm tryin to figire out which pistons should i order, p30 or ctr...can you guys help out? or recommend somethin else.Also with the aem tru time cam gears with 3 nuts hold it. I heard stories where they slip, is that true?
Modified by aznstyler119 at 5:27 AM 4/28/2005</TD></TR></TABLE>
I'm running the AEM Tru-Time gears.. never had a problem. The 3 bolt design isn't too bad at all, because the 3 bolts are actually bigger than the bolts in the 5 bolt cam gears.
What motor are you working with? P30s are good, but the CTRs will yield more compression... all depends on what you're putting them in.
Sorri i didn't give enought info. I'm working with a GSR motor, i'm leanin toward the p30 caues i'm worried about how high the compression is going to bump up to, plus i still want to be running on 91 oct. gas
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice »</TD></TR><TR><TD CLASS="quote">The jdm itr piston will be perfect with those cams...without question</TD></TR></TABLE>
good call.
i run the tru-time gears without ever having them slip. Steph runs them in his drag car so i think you'll be safe
good call.
p30 are good....
as far a cam gears i think generally if you can have a 5 or 6 the load is better distributed and would be a little bit safer as far a slippage goes....but if some people are telling you from experience that 3 bolts gears are fine then maybe they are right too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paris »</TD></TR><TR><TD CLASS="quote">I think pr3 pistons are like 11:1 to 11.5:1 in a gsr.</TD></TR></TABLE>
the p30's give out 11.5:1. I have those in my gsr.
