oil light flickering / no power above 3k rpm
Old Apr 27, 2005 | 08:03 PM
MugenFlaredCRX's Avatar
Default oil light flickering / no power above 3k rpm
the problem arose out of nowhere. one day the car was running perfect with no problems. the car sat for 2 days while my valve cover was being powdercoated. threw the valve cover back on. and no more then 10 miles after that the oil light came on. when i start the car the oil light would flicker at idle until it gets to about 1250rpm and it would go away. when i drive the car it would be fine until it hits 3000rpm and there will be absolutely no power as if i wasn't even pushing the gas down. there's some ticking coming from the engine. does anyone have any similar problems?
Old Apr 27, 2005 | 08:04 PM
EL Vap133's Avatar
Default Re: oil light flickering / no power above 3k rpm (MugenFlaredCRX)
Have you checked the oil? Did you remember to put the ground wire back on the valve cover?
JoeJITSU's Avatar
Im hoping its not your bottom end. OUCH!
Old Apr 27, 2005 | 08:08 PM
Default Re: oil light flickering / no power above 3k rpm (JoeJITSU)
oil level is fine, ground is on, i've checked everything but internals
Old Apr 27, 2005 | 08:53 PM
LSVTEC 91 Civic's Avatar
Banned
Let's hope your rod bearings aren't trash... Pull the oil pan off and check things out. Your oil pump could have went to **** too.
Old Apr 27, 2005 | 09:03 PM
91civicEX's Avatar
Default Re: oil light flickering / no power above 3k rpm (LSVTEC 91 Civic)
did u have anything covering your head? isuggest an oil change since u dont know if any cats or bugs crawled in there.
Old Apr 27, 2005 | 09:39 PM
ecovillain's Avatar
Default Re: oil light flickering / no power above 3k rpm (91civicLX)
theres a cat in my head! lol.
Old Apr 28, 2005 | 09:09 PM
91civicEX's Avatar
Default Re: oil light flickering / no power above 3k rpm (ecovillain)
hey u never know. haha
i was gonna say cat ****. but then it wouldnt make sense because cat **** cant crawl. so the **** was implied.
Old Apr 28, 2005 | 10:07 PM
TiMMaYBoYiE's Avatar
Thats not a good sign when the oil light comes on and levels are fine. Have you run a compression test? Your oil pump could be going out on you. If you have VTEC, does it work? If so how high are the RPMS when it kicks in and are they normal? Just be prepared for the worst!
egzboy
Jun 5, 2007 03:26 PM
dwynn73
May 19, 2005 06:42 AM
MugenFlaredCRX
Apr 27, 2005 10:47 PM
alb_accord
Feb 1, 2005 03:38 PM
Lshatchy91
Jun 10, 2004 08:27 PM
