Something wrong with my...........
Old Apr 27, 2005 | 05:40 PM
EDVxRICHARD's Avatar
Default Something wrong with my...........
I have just baught a 1992 honda civic cx and i just seen my lil coolant thingy empty so i filled it up and that **** went down........i dont really drive it alot ive only moved it around to either wash my car or im in the way of my moms parking....and in my exhaust ives seen little steam come out and my pipe is a lil rusted on the inside...........any more details just ask.......
Old Apr 27, 2005 | 06:02 PM
civictildeath's Avatar
Default Re: Something wrong with my........... (EDVxRICHARD)
the steam and rust in the exhaust is probably normal as ive seen it many times. i would fill up the rad and over flow tank and run for a bit cause you rad could be low or have an air bubble
B1894civic's Avatar
Old Apr 27, 2005 | 06:14 PM
EJ8VTEC's Avatar
Mr. Indecisive
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EDVxRICHARD &raquo;</TD></TR><TR><TD CLASS="quote">I have just baught a 1992 honda civic cx and i just seen my lil coolant thingy empty so i filled it up and that **** went down........i dont really drive it alot ive only moved it around to either wash my car or im in the way of my moms parking....and in my exhaust ives seen little steam come out and my pipe is a lil rusted on the inside...........any more details just ask.......</TD></TR></TABLE>
wow, dont u realize the level of coolant in your overflow tank changes b/ there is some in your radiator, depending on how hot the engine is. The level fluctuates also if you are driving and there is cool air hitting the rad
Old Apr 27, 2005 | 06:43 PM
Default Re: Something wrong with my........... (civictildeath)
Wat are Air Bubbles????.....and thanx for the help......
Old Apr 27, 2005 | 09:28 PM
EJ8VTEC's Avatar
Mr. Indecisive
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EDVxRICHARD &raquo;</TD></TR><TR><TD CLASS="quote">Wat are Air Bubbles????.....and thanx for the help......</TD></TR></TABLE>
????? Search........
Old Apr 27, 2005 | 09:33 PM
snoochtodanooch's Avatar
Default Re: Something wrong with my........... (CoupeVtec2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoupeVtec2k &raquo;</TD></TR><TR><TD CLASS="quote">
????? Search........</TD></TR></TABLE> awesome answer from a dude who has been a member for a month, congrats for doing absolutely nothing.
Air bubbles get into the cooling system and would prevent the engine block and radiator from being entirely filled, allowing the radiator to seem full then empty once the water pump runs and the car reaches temperature. Let the car come up to temperature and "burp" the system by removing the radiator cap and adding more antifreeze.
If your headgasket goes you will likely see antifreeze in the oil and or lots of steam out the back.
Old Apr 28, 2005 | 12:12 PM
Default Re: Something wrong with my........... (snoochtodanooch)
yea have seen antifreeze in my oil not alot but a little bit and i mean a size of a 25 cents so i should change my head gasket?
Old Apr 28, 2005 | 12:18 PM
POE's Avatar
POE
yeah man if u are gettin coolant into your oil, thats not good, it will get worse if u let it go... also when u take that head of if u want a little more power swap on a SOHC vtec head. u allready have the head off just buy a new head for 150 and a new ecu for 100 and u got some power and no coolant leak.
Old Apr 28, 2005 | 12:41 PM
Econo'Box's Avatar
Default Re: (POE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by POE &raquo;</TD></TR><TR><TD CLASS="quote">yeah man if u are gettin coolant into your oil, thats not good, it will get worse if u let it go... also when u take that head of if u want a little more power swap on a SOHC vtec head. u allready have the head off just buy a new head for 150 and a new ecu for 100 and u got some power and no coolant leak.</TD></TR></TABLE>
I'm gonna agree with him. I'm waiting for my gasket to go so I can do this.
Old Apr 28, 2005 | 01:19 PM
whitecat31's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EDVxRICHARD &raquo;</TD></TR><TR><TD CLASS="quote">yea have seen antifreeze in my oil not alot but a little bit and i mean a size of a 25 cents so i should change my head gasket?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by POE &raquo;</TD></TR><TR><TD CLASS="quote">yeah man if u are gettin coolant into your oil, thats not good, it will get worse if u let it go... also when u take that head of if u want a little more power swap on a SOHC vtec head. u allready have the head off just buy a new head for 150 and a new ecu for 100 and u got some power and no coolant leak.</TD></TR></TABLE>
If you live in California, make sure the HEAD you put on is legal, or you can lose you car if pulled over. Normally, HEAD swaps, are a referee violation, that can get your car the inoperable status.
You can also fail at the smog check, if the smog guy has any brains.
If you live in California, and have a choice between a head swap or an engine swap, the safer route might be an engine swap. Too bad it is not a cheaper.
I have heard about people shaving the head a little and putting a thinner head gasket to increase the compression.
Anybody here do that? How did that work out?
Old Apr 28, 2005 | 03:59 PM
Default Re: (POE)
if i get the sohc vtec and the chip.....will i have to tap the block for the fuel line?.......or can i just straight up slap that bitch on........
Old Apr 28, 2005 | 04:12 PM
WildPig's Avatar
Default Re: (EDVxRICHARD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EDVxRICHARD &raquo;</TD></TR><TR><TD CLASS="quote">if i get the sohc vtec and the chip.....will i have to tap the block for the fuel line?.......or can i just straight up slap that bitch on........</TD></TR></TABLE>
Huh? Research mini-me swaps....... they are just straight bolt on other than a little wiring.
And it's not a "chip," you need an entirely new ecu from the same year car that you get the vtec head from........
lilboxx
Jan 30, 2012 05:32 AM
beginmyhonda
Aug 23, 2008 05:36 PM
UNKNOWN_MEMBER
Mar 14, 2007 05:52 AM
Captain Flaps
Nov 23, 2005 04:46 PM
sosleepy
Sep 11, 2005 06:43 PM
