need help asap...tranny code 4spd or 5
Old Apr 27, 2005 | 03:05 PM
Import_lifestyle's Avatar
Default need help asap...tranny code 4spd or 5
just as the name implies i have a tranny i bought for my swap.(d16z6)..and i bought a cable tranny for it so i wouldnt have to go through the whole cable to hydro ****....and we put the shift linkage in and it seems to only be a 4spd...which would really **** me off...anyhow...heres the tranny code any help would be greatly appreciated.....SL3 5047649....if you know if its a 4 spd or 5 spd pls lemme know
Old Apr 27, 2005 | 03:08 PM
Super79Dave's Avatar
Default Re: need help asap...tranny code 4spd or 5 (Import_lifestyle)
does it have a tin cover on the far right of the car if so inside that cover is fifth gear
Old Apr 27, 2005 | 03:15 PM
well im at the library right now on the comp...it was closer to my house....soo i dont remember..the thing is the junkyard i bought it from gave me a 4 spd the first time...then i returnrd it very pissed off..n they gave me this one...i bought an exedy clutch meant for a 5 spd..and it fit perfectly....
Old Apr 27, 2005 | 03:43 PM
were you being sarcastic or you bein serious...???
Old Apr 27, 2005 | 11:35 PM
also i used the stock shift linkage off the d15b2....dont know if thats the problem...n i still got the linkage off the z6 so ill just go ahead and swap em out if thats the case...some1 plz help wit info on this
Old Apr 28, 2005 | 06:24 AM
jlicrx's Avatar
Default Re: need help asap...tranny code 4spd or 5 (Super79Dave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Super79Dave &raquo;</TD></TR><TR><TD CLASS="quote">does it have a tin cover on the far right of the car if so inside that cover is fifth gear
that would be true for 84-87 Civic/CRX, but not 88-91 - they all look the same from the outside - 4spd and 5spd use the same case - could be a 4spd, but the only SL3s i have seen were 5spd from 91 DX - shift linkage is the same in all 88-91 4spd or 5spd
Old Apr 29, 2005 | 06:47 AM
****** A now im stuck with 2 4 spd trannies
Old Apr 29, 2005 | 06:50 AM
dr_latino999's Avatar
Default Re: (Import_lifestyle)
What is wrong with a four speed tranny? Just change the FD to something in the area of 4.7 and call it a day
Old Apr 30, 2005 | 08:05 AM
well i picked up the Si tranny today...and im gonna go and put it on later....turns out it was a 4 spd.....*******....but the one i got now is def. Si....i check the codes....
Simj561
Feb 22, 2015 02:32 AM
tony7626
Jan 22, 2010 03:56 PM
DroopyHatch
Feb 20, 2005 11:22 PM
vteckilla7
Aug 11, 2004 07:15 PM
deagleEF8
Apr 26, 2004 08:19 PM
